HELP.... please
I have a question and I have done some research but I'm just curious....has anyone taken their bed apart I've noticed that on the front of my bed that panel has bolts that you can remove and subsequently remove that panel I'm sure it is not as easy as it looks is there any welds holding it in place or can I remove those bolts and remove that panel to replace it
![]() Join Date: Feb 2014
Re: HELP.... please
I took an 86 bed apart back in 1995. The panels are all bolt together. The front panel of the bed fits into an area in the top of the side panels. The front panel "can" be replaced without removing the side panels but it is a pain to get it fit back together properly. It is much easier to remove one of the side panels when attempting to replace the front. The old seam sealer may hang up you a bit when taking the bed apart. Watch out when using an aftermarket front panel as the bolt holes will not always match up. Once they are assembled you go back over the seams with seam sealer to prevent moisture from getting down in the seams and rusting them out.
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
Moderator
![]() Join Date: Oct 2008
Re: HELP.... please
Some may have welds around the back stake pockets.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Re: HELP.... please
Thank you so much....my truck is being painted right now I gave this guy a chance that just came out of school he paint his backyard. And judging by the picture he sends me he's doing a great job
Post Whore
![]() Join Date: Aug 2014
Re: HELP.... please
check out this dude's thread Restoring Rusty I think the bed work starts on thread #1871 he takes it all apart paints it and puts it all back together, lots of pics, cool dude
Re: HELP.... please
front panel can be removed with the bolts and not removing the sides. the sides are held on the bolts on the front panel, bolts in the wheel well, and the weld on the floor of the bed by the hinge.
Re: HELP.... please
A little help here how do you get to the top bolt that holds the upper hinge 1978 chevy truck thanks for the help guys
Re: HELP.... please
Hotrodron.....are you talking about the upper door hinge? If so, look under your dash with a trouble light. You will see a rubber plug quite high up on the "kick panel". My truck had a wire running into the center of it. Pop out plug, and reach in with a 9/16" socket with ext. Careful ..... if your socket falls off its gone.....
Re: HELP.... please
The front panel just comes off easily when you remove all of the bolts around the perimeter. I replaced mine with one from the junkyard. The sides panels move around a bit but they stay in place. I used a couple of screwdrivers to hold the front panel in place until I got a few bolts installed.
Re: HELP.... please
Got the bolts out guys. Because i am putting on new dash pad and gauges. I was abe to get to bolts from the top through the glove box area ,and the left side ac vent. Thanks again ,yes tape the socket to the extension.
