Windshield washer pump
I can here the pump click when I press the wiper button but it is not pumping any water. Is there a trick to get the pump going or is it a bad pump?
![]() Join Date: Jan 2001
Re: Windshield washer pump
The diaphragm in the pump is likely shot. You can rebuild the pump, but there's also the option of putting a later-model pump on it. It's a pretty popular upgrade.
Yours did more than mine when mine was only 19 years old! According to the original owner, the washer pump never worked, not even the day he drove it off the new car lot!
Here is what I did, Trico pump from O'Reilly's and a bracket I made out of some aluminum TV base someone tossed in a dumpster. I cut out a bracket with a dremel tool and made spacers to give me enough room to tighten down the lock nuts. I still have to hook it up. ![]() |
![]() Join Date: Oct 2004
Did you prime the lines? I had the same issue until I filled all the lines with washer fluid.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners ![]() 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
Thanks for the replies. Truckster do you have info on the upgrade?
