front in suspension suggestions
I have added PS, PB, and AC to my 57 3100. Everything else is all original. It seems the extra weight or just age is causing what I would refer to as "bottoming out" when I hit larger than average bumps in the road. No problem with the rear end. Any suggestions on how I can easily beef up the front suspension?
Post Whore
![]() ![]() Join Date: May 2015
Re: front in suspension suggestions
Replace springs..over time they will loose their rating and sag.if theive never been replaced they are about 60 yrs old..new shocks will help as well..
I have replaced the shocks and it helped. Was hoping to avoid $$$ leaf spring replacement. thanks for your post
Post Whore
I have a 57 international and the spring on the drivers side collapsed...so they will give out over time
A320 Pilot/USAF Retired
You might be able to have them re-arched, if you can find someone who still does this.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#6 | |
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
