08-10-2016, 11:40 PM | #1 |
Fuel Line ?
Is there any Place or anybody that makes the small block Fuel Lines Pre Bent to there original shape from the pump up to the carb for Small Blocks?
I have my Alternator on the pass side and it just might get in the way of the fuel line for clearances. I bought a pre bent line from The Truck Shop in Orange that was for a 71-72 350 with 4 bbl Holley that matches the fuel pump outlet 3/8's fitting. I do have a 4 bbl Holley that's why I got that one. It didn't fit so I tried to make the bends a little different too fit my fitment. That didn't work. Any help would be Appreciated, Thanks |
08-11-2016, 12:39 AM | #2 |
Re: Fuel Line ?
check out inlinetube.com
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Thank you all so far you are angels!! Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
08-11-2016, 12:59 AM | #3 |
Re: Fuel Line ?
You might want to try one for a 71-72 car instead of a pickup. They had the alternator on the passenger side. They also had a long water pump, but that shouldn't matter.
08-11-2016, 02:07 AM | #4 |
Re: Fuel Line ?
Bending one's own fuel line from Poly Armor tubing is a bit annoying and there is some trial and error but if a complete noob like me can do it, anyone can.
I bought a cheap Harbor Fake Tools bender from ebay.com and did a better job than factory. If you have access to a long table (standard workbench) you will do just fine. I used a Craftsman double flare kit for the bubble flares. |
08-11-2016, 11:21 AM | #5 |
Re: Fuel Line ?
I used a fuel line set from The Right Stuff Detailing (http://www.getdiscbrakes.com/fpc67zz) which was made for the 67/68 Camaro Z28s which used a Holley carb on a 302 cubic inch engine with a short water pump. As you can see in the link, it is out of stock. However, Inline Tube sells the lines and brass block separately (part numbers CCE6705 and CCE6710). I did have to do some minor tweaking.
08-11-2016, 12:18 PM | #6 | |
Re: Fuel Line ?
Isn't a small block a small block is a small block? Maybe the Alt. is in the way from being on right side of engine being the problem! I think some Cars had it that way so why is it so hard to find a pre bent fuel line for a small block?? Whats next guys "rubber" I have that now & I want a cleaner look than that, any one can do "rubber" I am not that one. thanks Last edited by ck5566; 08-11-2016 at 12:24 PM. |
08-11-2016, 01:48 PM | #7 |
Re: Fuel Line ?
Here's a vote for Right Stuff over Inline. Inline has been nothing but grief and annoyance unless it's a 1969 Camaro small block. At least for me, your mileage may vary.
08-11-2016, 02:00 PM | #8 |
08-11-2016, 03:06 PM | #9 |
Re: Fuel Line ?
The fuel pump on a 305 is on the same place as it is on a 350, 327, 400, and so is the carb. What really matters is what side the alternator is on and the water pump.
I made my own fuel line out of braided nylon line and AN fittings. There is even a 7/8" -20 fitting available that threads right into a quadrajet with a -6AN male fuel inlet barb.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
08-11-2016, 04:45 PM | #10 |
Re: Fuel Line ?
So far I haven't even gotten out of the driveway with them ~*^#`>@ !!!
08-11-2016, 04:49 PM | #11 | |
Re: Fuel Line ?
So where is a person to go from here? |
