Brake Drum Adjustment - New drums
So the old drum had a access port on the Drum itself... Usually see that on the backing plate.
New drum does not have it. Do you guys do something different? cut a hole in the backing plate? ![]()
1968 GMC truck 910 Trim (Canadian) 127" WB 3 on the Three Trans (Saginaw SM330) 250 ci L6 Engine HEI ignition (early 80s L6) |
Re: Brake Drum Adjustment - New drums
I kind of wondered the same thing. I thought of just putting a hole in the drum like the original, can't understand why there isn't one in the backing plate.
I had the same issue, so I took it to a local machine shop and they put holes in both drums for $20CAN.
I thought about that. Did you notice it out of balance after that though?
