Old 10-05-2003, 01:51 PM   #1
67sss
67sss's Avatar
Question auto tranny shifting ?
auto tranny won't shift automatically but will shift manually. Anybody have any ideas why?
Thanks.
67sss is offline   Reply With Quote
Old 10-05-2003, 01:55 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Check the vac line. If it is still hooked up, then you have some very expensive problems.
The vac line is the only external thing that would cause this.
Old 10-05-2003, 06:17 PM   #3
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Yup, sounds like the vacuum line fell off the vacuum shift modulator. Been there, did that. Drove to the auto parts store to get a new modulator, crawled under it to see what style it was, and it was disconnected. Wasted trip!
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 10-05-2003, 07:40 PM   #4
Spoof
Spoof's Avatar
It may have been a wasted trip but I bet you were still happy!
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 10-05-2003, 09:26 PM   #5
jorgensensc
jorgensensc's Avatar
I had the same exact problem. Did the same thing ' crawled under the truck to see what modulator' and my vacuum was still hooked up. I unhooked it to look at the adjustment screw and found a little trash. Blew it out and ooked it back up. Problem solved.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-05-2003, 10:43 PM   #6
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
i agree with the vacum
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 10-05-2003, 11:00 PM   #7
67sss
67sss's Avatar
So here's scoop. It works now. First I took the line off the carb and sucked on it to make sure the modual was working and it was. Then I hooked the other end to a different port on the carb. and it worked. Now I know to check the vacuum port of carbs B4 I go any farther.
Thanks for the info.
