08-11-2016, 02:29 PM | #1 |
Remove door hinges
How do you get the top hinge bolt out to remove hinge looked under dash didnt see a hole to get to the bolt
08-11-2016, 02:36 PM | #2 |
Re: Remove door hinges
There are holes under there. Use a flashlight if you need to.
08-11-2016, 02:39 PM | #3 |
08-11-2016, 08:35 PM | #4 |
Take the front fender off, makes it easier to adjust the door.
Beer helps. |
08-12-2016, 10:00 AM | #5 |
On some trucks there is a rubber plug or grommet in the hole that needs to be removed.
