door locks
When the door is locked is the key slot supposed to run horizontal or vertical?
Re: door locks
horizontal when you lock it from the outside of the truck with the key...
1990 Silverado Sport 2010 Silverado K1500 1996 K2500 |
Re: door locks
Also, depending on your year(60-61 -62?), ONLY the passenger side had the lock, IF you are going back OEM authentic.
I still added the lock to the drivers door.........
http://s1299.photobucket.com/user/jb...23904108567829 |
![]() Join Date: Jun 2015
Re: door locks
Seriously? Only the passenger side? What were you supposed to do when you didn't have a passenger, crawl across the seat to unlock the driver's door??
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: door locks
Drivers door came with the keyed lock, the passenger side did not. It was optional to have a passenger side keyed lock. And yes, if you wanted to unlock the passenger door that did not have a keyed lock on the exterior, you had to lean across and use the interior door handle to let them in.
There was a promotional Rain Bonnet offered by the salesmen to prospective clients wives. lol
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#6 | |
Re: door locks
Google it.
#7 | |
Re: door locks
I remember the leather key case...a lot of people used them back in the day...
Re: door locks
My 1960 Apache C-10 Custom Short Step Had Door Locks On Both Doors.
1961 C-20 Apache Also Had Door Locks On Both doors. 1962 C-10 Long Fleet - Both Door Locks. 1956 3100 - Only One Door Lock On Passenger Side. |
Re: door locks
Having bucket seats would have been REALLY inconvenient...
Re: door locks
We have two Chevys at work, an '11 & a '10. The '11 has locks on both sides, but not electric. The '10 only has it on driver's side! What moron at GM decides that a modern pickup only gets one lock???
Re: door locks
A lot of cars built in the last fifteen years or so only have one door lock cylinder.
Re: door locks
My 64 c10 has one door lock on the drivers side
#13 |
Registered Truck Offender
Re: door locks
Same with my 66 C-10. Drivers side only (and was original doors to the cab, no signs of ever being repaired or replaced)
BUT, JB is absolutely correct. My 50 5window 3/4 ton only had passengers key lock. but the 58 has NO keyed handle either side,,, but the 59 had Dirvers side only. So I'd suspect the practice of Passengers side only key lock must have ended some time in the 50's. Unless I'm mistaken,, starting in ~about 2012ish GM puts only Drivers side key lock,, and a key fob that unlocks everything with the press of a magical button.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#14 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: door locks
Most everything was bench seats.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#15 | |
Re: door locks
