08-12-2016, 08:04 AM | #1 |
another blinker question
i have a 7-wire 900 series blinker i installed a 3-way flasher everything works fine except the little blinker lights on the switch itself any ideas thanks
08-12-2016, 08:18 AM | #2 |
Re: another blinker question
i was just thinking i painted my column its proberly a ground issue thanks
08-12-2016, 09:54 AM | #3 |
could be the bulb inside the unit on the column is burned out. mine only has one bulb. try that first. I think the unit grounds thru a wire to the body not thru the signal assembly to the column
08-12-2016, 10:47 AM | #4 |
Ok thanks
