View Poll Results: Rough 1970 c30 is it worth a grand
Yeah 7 63.64%
No way 2 18.18%
Depends on how crazy you are 2 18.18%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
Old 08-12-2016, 09:04 AM   #1
Brysenj
Brysenj's Avatar
Exclamation 1970 c30 what to look for
Okay I'm looking at what a guy says is a 1970 c30 with a 292 and 4 in the floor with a flatbed 😃 But have never played with c30s just a 1970 and 1971 c10 what are some things I want to look at and for with a c30 don't even have an idea it's kinda rough and need to know what to look for
Thanks for the help
Brysen and his trucks
1971 Custom/10 (the big c10)
1970 C/10 (the gold truck)
Brysenj is offline   Reply With Quote
Old 08-12-2016, 09:23 AM   #2
68350
68350's Avatar
Re: 1970 c30 what to look for
One tons are the same truck as any other 67-72. It will have the raised pod cab lights if it's original cab.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 08-12-2016, 09:44 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by Brysenj View Post
Okay I'm looking at what a guy says is a 1970 c30 with a 292 and 4 in the floor with a flatbed �� But have never played with c30s just a 1970 and 1971 c10 what are some things I want to look at and for with a c30 don't even have an idea it's kinda rough and need to know what to look for
Thanks for the help
If you can, post some pictures of it.
As with any '67-'72 truck, check the cab supports, kick panels, around the heater box on the firewall side, above the windshield on the inside, and the drip rail on the outside. Any bubbles in the paint and you can bet there will be a rust hole underneath it....
The easiest way to tell if it still has the 292 I6 is that the metal lifter covers on the passengers side of the block are approx. 6" tall on the 292 I6 and approx. 4" tall on the 250 I6.
Brake parts can be hard to find for them so keep that in mind.
LockDoc
Leon
Old 08-12-2016, 11:58 AM   #4
hugger6933
Also keep in mind that the same ideas work on the C30 as do the C10's. For instance disc brake change overs from the newer square bodys are a great way to put disc brakes on and they would have the one piece wheel to get you away from the "widow maker" split rim. Also some of those one tons are geared real LOW and you can find newer rears[out of the squares] as high as 3:42. Those would help really make a much more enjoyable truck. Mine is a 71 so it has disc already. It has No power steering so thing like that change over are just like the lighter type trucks.
hugger6933 is offline   Reply With Quote
Old 08-12-2016, 02:04 PM   #5
cypressbog
Go Pack Go!
Pretty much the same things you would look for in a C10 or C20. 1 ton should have a HO72 rear end.
cypressbog is offline   Reply With Quote
Old 08-13-2016, 08:32 AM   #6
They are worth the same as a C/10 in that condition. Just a matter of what configuration is desired. Use your own judgement. If you want a C/30 it's worth it (if you think a C/10 in same condition is)
