08-12-2016, 01:06 PM | #1 |
Cheap wire looms from zip ties
If you've never done it, this might be close up enough to give you the idea. Cheap and easy to make with zip ties and keeps the wires nicely spaced and organized. And of course when it branches down to 3 or 2 wires, you can just make smaller ones.
08-12-2016, 02:21 PM | #2 |
Re: Cheap wire looms from zip ties
That looks really nice!
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
08-12-2016, 02:41 PM | #3 |
that's exactly what I did! $6,000 motor and I cheapo'd out on the wire looms. haha
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
08-12-2016, 03:11 PM | #4 |
I just can't seem to figure out how you did it. My damn eyes ain't what they used to be
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
08-12-2016, 03:34 PM | #5 |
Here ya go: https://www.youtube.com/watch?v=Fll_OPtYsJE
I did the same thing. I bought the wire guides that go along the valve covers and I bought some wire separators from Taylor. They both were junk and I ended up doing this with black zip ties. Works great, looks great. Oh yeah, and basically free. |
08-12-2016, 03:52 PM | #6 |
For this set up to look good, I think you would have to have custom-length wires or trim them for length and re-crimp the ends. Most wire sets you buy today are all way too long.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-12-2016, 04:02 PM | #7 |
I know mine are too long. Makes it look like chit. Any insight on what crimping tool is needed to shorten the plug wires or where to get new terminals to crimp on?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15 GM 4 bolt 880 roller block, 062 Vortec Heads Comp Cams XR258HR-10, MSD Street Fighter HEI Edelbrock: Performer Intake 2116, 1405 Carb Long tube headers, 2.5" duals to Flow Master Super 40's Vortec Engine Build |
08-12-2016, 04:12 PM | #8 |
Yep, this is just for the dyno, but cut-to-length are the way to go. I've got 3 too short and 2 too long!
08-12-2016, 04:12 PM | #9 |
What I have used before is a pair of wire cutter/stripper/crimpers. I used a small screwdriver to pry the factory crimp loose, then cut the wire to length with the cutters, and used a razor blade to cut the outer jacket off. Then used the crimpers to re-crimp it.
My Craftsman crimpers have a spot that is the right size for the plug wire terminal.
08-12-2016, 04:42 PM | #10 |
Yeah mine are too long but I was able to manage them with these the way I wanted. Cutting your own seems like the way to go, maybe next time when I know exactly how I want them.
