Old 08-12-2016, 03:36 PM   #1
Aaronf99
HEI 14003 distributer chevy c10 350 engine
hello my Chevy c10 is stalling or not starting so we replaced the spark plug wires but on the distributer the plug that goes under the ground cables there is only one a red one I'm not to familiar with this type of truck the truck still wont run or it just stalls any help I have pictures of the engine and the distributer
Aaronf99 is offline   Reply With Quote
Old 08-12-2016, 04:54 PM   #2
webfoot
Re: HEI 14003 distributer chevy c10 350 engine
So there is only a red wire hooked up to the distributor? That is all you need for power. The other terminal is for a tach. make sure it has a full 12 volts. Also, make sure the ground strap is in the cap, and you have properly grounded the coil.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 08-12-2016, 09:50 PM   #3
Aaronf99
we got the truck running again the carburetor was clogged up with gunk from the gas
