angle strips
Any suggestions on the angle strips on my 66 stepside. The sides on the bedside are fine but the bottom half at the wood is rotted away. I know you can get the angles from mar-k. Can i cut of the bottom rot and just set the replacement over the rest or will it leave a gap at the wood.
Re: angle strips
Just did my angle strips not bad of a job if u got good drill bits and vice grips
Re: angle strips
Did you have them made or buy replacements? I got a steel floor welded over mine & I'm gonna destroy them getting that floor out. I thought about getting my metal shop boy to brake me out a set of a thicker gauge, the originals sure are thin.
Re: angle strips
Mar-k if putting new floor will in will b a must good luck it will b worth it
Re: angle strips
thanks enduro
just finished taking the bed apart. i think i will get the cover up ones and cut the bad part off that meets the wood |
Re: angle strips
thanks andyh
think i figured it out if you dont know about mar-k.com check it out |
Re: angle strips
I bought a whole bed kit from Mar-k (oak wood, stainless strips, bolts, angle strips). Sitting in the garage as I got it imported in to New Zealand with the truck, will prob install it soon. Will start a build thread for my truck soon also.
Re: angle strips
Thanks!
