Old 08-13-2016, 09:20 AM   #1
RANDY COX
RANDY COX's Avatar
K20 front axle
My son just got an 82 K20 and it needs the driver side front axle, my question is will a 1/2 ton of the same yr or yrs work, I know on my truck it originally had 3/4 ton suspension and I went with 1/2 ton and was able to use the front lockouts and outer gears in the 1/2 ton..I'm thinking that it's just the outer hub that's different for it to be 8 luggers...Oh and I think it's a 10 bolt front axle in the 82...the axle apparently had a bad universal joint and was snapped that messed up the axle cause the joint is destroyed...Thanks for the help gentlemen...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-13-2016, 10:02 AM   #2
ryanroo
ryanroo's Avatar
Re: K20 front axle
it should work coming from either a k20 or k10. the splines and lengths are the same.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 08-13-2016, 04:12 PM   #3
RANDY COX
RANDY COX's Avatar
Re: K20 front axle
Thank You sir...
1964 BBC 402 4x4
