08-13-2016, 03:59 PM | #1 |
driveline angle experts??
Hello all,
I am in need of some advice here. I have a 67 c10 stepside. I dropped it down 6 in the rear using 6" lowered springs, and 3 in the front, 2 dropped spindles, 1 dropped springs. A couple of years ago I swapped out the TB350 for a 700R4, had a new driveshaft made, one piece shortened 3 from the shaft for the TB350, new ujoints. The truck had an annoying high speed vibration that I wanted to resolve. So recently, I took my initial measurements and purchased 6 coil spring shims for the rear. I have the transmission shaft and the pinion where I believe they should be and work. The truck seems fine until I put into overdrive then it feels like the driveshaft is going to come thru the floor and I actually lose power in the truck. I have checked the timing to make sure its not the timing, timing is correct. I should also add it seems to run fine vibration free until put into overdrive. I am planning on changing plugs and wires next, but prior wanted to ask for any feedback. The truck did not run like this prior to these new changes. I can not move the transmission up without cutting the floor of the truck, which I really rather not do. Current measurements are: Transmission shaft 5 degrees up Pinion is 5 degrees down. Transmission slip yoke bearing cup is 5 degrees up Pinion yoke bearing cap is 5 degrees down Driveshaft bearing cup: 2 degrees up in the front 2 degrees down in the rear. Driveshaft angle is 1 degree up I believed this to be an Operating angle of 3 degrees The transmission and pinion are at the same angle, but are opposite. I can have the shaft and joints checked, but the weights are still on the driveshaft and there is no play when I grab the DS and try to move. Am I missing something here, are our trucks different? Any advice or suggestions sure be appreciated. Thank you. |
08-13-2016, 04:51 PM | #2 |
Re: driveline angle experts??
Maybe this will help you figure it out.
http://www.drivetrain.com/parts_cata..._problems.html |
08-13-2016, 06:05 PM | #3 |
Just noticed your timing thought!
What is your timing curve like? And what carb? |
08-13-2016, 07:11 PM | #4 |
Thank you for the reply.
As stated the truck was running fine with a bit of vibration last week before I started this. Carb Holley street avenger 670 jetted I think I have 71 mains now, don't remember what I have for secondary's. Timing 12 initial about 33 at 3000 rpms. On a built ZZ4 create, RHS heads, thumper cam... Truck seems to run fine in 3rd and 4th, it's when I put it in OD, I can FEEL the DS shaking below, I do seem to lose power, so of course up for any suggestions. |
08-13-2016, 08:09 PM | #5 |
You might be jetted too lean plus not enough initial timing.
And your thumper cam doesn't like running at a low rpm. Have you tried more initial timing to see if it gets better? What rear gear ratio do you have? |
08-16-2016, 08:56 PM | #6 |
Thanks for the recommendations! I figured it out, trucks running nice and smooth till 80 and I don't go much over that anymore.
It was the cheap gauge I was using, was not very accurate. I loaded the Tremic app for the Iphone and within and hour I had all green, which indicates good angles. So thanks again. I highly recommend this free app. |
08-17-2016, 09:25 AM | #7 |
soo your trans and pinion angles were way off causing your problem?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
