Old 08-14-2016, 06:20 PM   #1
Tuff Gong
Tuff Gong's Avatar
GM 8 track player install question
anyone out there ever installed one of these? I would like to test my unit but have not idea where to start.
Tuff Gong is offline   Reply With Quote
Old 08-14-2016, 06:53 PM   #2
Tuff Gong
Tuff Gong's Avatar
Re: GM 8 track player install question
Some of the wiring has been altered over the years and it is not really making sense to me what goes where. It appears the radio speaker attaches directly to the 8 track player and speakers look straight forward (see pics).
Old 08-14-2016, 06:55 PM   #3
Tuff Gong
Tuff Gong's Avatar
I'm having trouble with the power wire and additional stuff on the harness. Here are the pics of those wires.
Old 08-14-2016, 11:15 PM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I bought me a manual like this, but i haven't installed this into my crew cab yet.
http://www.ebay.com/itm/1970-CHEVROL...AAAOSwstxU70XF
Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 08-14-2016, 11:31 PM   #5
Tuff Gong
Tuff Gong's Avatar
Trevor
Any chance you can confirm the manual covers installation? Or perhaps post a couple pics?
Old 08-15-2016, 09:44 AM   #6
100%Chevy
Have you looked inside the covers on the radio/8-track player?
Sometimes there is a hook-up/color code diagram inside.
Mike.
100%Chevy is offline   Reply With Quote
Old 08-16-2016, 01:17 AM   #7
burb71
Active Member
Here is a hook up instructions sheet for wire harness, and where and how to mount speakers.
Sorry this is the only pic I have of each saved.
I have not installed my own tape unit in my truck yet
burb71 is offline   Reply With Quote
Old 08-16-2016, 07:17 PM   #8
71blksuper4x4
SWB 4x4 Collector
Sorry, I was trying to locate it in one my totes, but it looks like Burb beat me to it. Trevor
TREVOR
Old 08-16-2016, 07:29 PM   #9
hardwaycooke
hardwaycooke's Avatar
Have a working pioneer 8 track in mine but had a shop install after I cleaned it and put in a new belt. dont forget the correct ohm speaker...
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 08-16-2016, 09:27 PM   #10
Tuff Gong
Tuff Gong's Avatar
Thank you for the responses. I'll take a look at the diagram. Hopefully it gets me to where I need to be.
Old 08-17-2016, 11:03 AM   #11
Tuff Gong
Tuff Gong's Avatar
It would really help if I could see an example of an uncut wiring setup. Based on the diagram I think my speaker wire off the 8 track is not correct. I also have no idea what the wire labeled as (?) connects to. I believe #4 is the main power supply. Anyone else have any thoughts? Thanks.
Old 08-17-2016, 01:57 PM   #12
burb71
Active Member
Here is the back of one of mine, I have two Original GM 8 track decks both have the same wires from the back.
There are three seperate wire connections from the tape deck.
Old 08-17-2016, 03:34 PM   #13
Tuff Gong
Tuff Gong's Avatar
One last question, hopefully! does the black wire on the 3 plug assembly connect to the speaker plug?
Old 08-17-2016, 03:41 PM   #14
Tuff Gong
Tuff Gong's Avatar
burb71, I really appreciate you taking the time to help me out.
Old 08-17-2016, 06:02 PM   #15
burb71
Active Member
There is a single plug lead also, (in added red box)
On the wiring diagram it says the 3 plug lead that go's from tape deck to radio,
1st lead... 14v DC
2nd lead... speaker
3rd... ground
The 3 plug lead from your center speaker plugs to the Crossover Network box.
Did I answser the question, or am I not understanding you?
Old 08-17-2016, 06:11 PM   #16
Tuff Gong
Tuff Gong's Avatar
That helps. I'm trying to figure out if the (? key note) in post #11 connects to the other harness your 8 track. Sorry if I am getting confused. Definitely not good with electrical
Almost 100% positive it does, just want to make sure.
Old 08-17-2016, 06:13 PM   #17
Tuff Gong
Tuff Gong's Avatar
I am going to use an old speaker harness and get mine back to original. As it sits, I don't have the attachment that goes to the existing radio
Old 08-17-2016, 06:45 PM   #18
burb71
Active Member
Just so you know, the single lead thats in the red box that I highlight, has 1 yellow wire
Old 08-17-2016, 07:15 PM   #19
Tuff Gong
Tuff Gong's Avatar
That is the power wire, correct?
Old 08-17-2016, 09:06 PM   #20
burb71
Active Member
I do think so, diagram says 14 v DC.
Old 08-17-2016, 11:32 PM   #21
Tuff Gong
Tuff Gong's Avatar
Thanks again for all the help. I figured that the 2 black wires that I see are ground wires and screw into the back of the unit. Can you confirm? No more questions after that. Haha
Old 08-17-2016, 11:55 PM   #22
burb71
Active Member
Im not sure, ill look at it again tomorrow
