Old 08-14-2016, 06:39 PM   #1
66clow
66clow's Avatar
Headgasket leaking?
I was having a small leak of oil running down at my starter nuts. Pulled starter and it appears a small leak running down from the head gasket. Is this typical at times? How hard on the difficulty scale? I've replaced a engine in a Mustang and have down numerous other bolt on stuff on cars. So I'm pretty handy. Looks like it would be pretty straight forward pulling carb, intake, exhaust and head. Would I do both gaskets since I'm in there? CHEVY 350 anything else to do while I'm in there? Or actually do I just try to tighten the head bolts? Just thought about that.
66clow is offline   Reply With Quote
Old 08-14-2016, 06:51 PM   #2
Mike C
Mike C's Avatar
Re: Headgasket leaking?
No, it's not typically. Usually blown head gaskets are between cylinders and not externally.
Is that oil or water? There are no oil passages through the head gasket. If it's oil, most likely a valve cover leak or rear of the intake manifold and it is wicking into the joint between head and block.
Check intake manifold, valve cover, and heater/cooling fittings for leaks first.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-14-2016, 07:05 PM   #3
66clow
66clow's Avatar
Well I feel better hearing that. It is definitely oil. I felt behind the valve cover before so may be intake. Thought it was the head since you could see oil lightly between the head and the block and a little trickle down the side to the starter. Leaves a little amount of oil after the truck sits after driving. Just bugs the mess out of me since I just fixed my trans pan gasket leak. So should I just be able to tighten the intake? Looks like the po had replaced it. So maybe needs retorqued
Old 08-14-2016, 08:15 PM   #4
geezer#99
geezer#99's Avatar
Spray or sprinkle a little baby powder back there on the intake and the valve cover. Your oil leak will show up easily.
Old 08-14-2016, 08:42 PM   #5
hugger6933
A retorque isn't gonna help. Most likely it is the pan rail gasket is starting to fail. The last person to work on it may have used the rail end gaskets[don't do that] or didn't put the needed daubs on the ends to stop the chance of a leak. Sounds like the intake may have to come off to fix the leak.
hugger6933 is offline   Reply With Quote
Old 08-14-2016, 10:37 PM   #6
garyd1961
Make sure you know where it's coming from before you do anything. Don't just assume it's not this so it must be that. The valve covers are known for leaking on these motors.
garyd1961 is offline   Reply With Quote
Old 08-15-2016, 08:35 AM   #7
Mike C
Mike C's Avatar
THe leak has to be from the top. The oil pan is WAY below the joint between the head and the block.
Valve covers are easiest but the intake rear seal is just as likely. If you used the rubber end seals on the intake and it is leaking, get a new gasket set and tube of Permatex. Throw end seals in trash. Re-do intake using Permatex on the ends of the block.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 08-17-2016, 12:50 AM   #8
66clow
66clow's Avatar
Put my phone behind the intake and took a photo. Appears it is my intake seal. Fingers were wet also when I reached back there. No sealant must of been put back there on the corners.
Thanks for the pointers.
