383 stroker running too hot
Hello, I have a 1972 c10 that i recently had my 350 replaced with a 383 stroker. According to the mechanic it has a 9:1 comp cam but no other info is known about it. He also installed a vintage air system at the same time. Now, when the temp gets above 90 degrees outside the engine runs too hot (don't know actual engine temp is due to gauge is stock) but about 3/4 of the way to max. If I turn on the AC it gets even hotter before I shut it down. I've replaced the 180 degree thermostat with same, and coolant is flowing through top hose. TH400 has a cooler in front the the AC condenser and blocking air flow ( see attached picture)
I did check my timing after reading forums. With dist adv plugged and 1406 edelbrock driver side port capped, the total timing is 41 btdc. At idle it is 25 btdc. I thought these number were off so I verified the balancer mark using a piston stop. It was right on (does a radical cam produce these types of numbers???) So I tried moving the timing around to see what the engine temperature would do, and nothing seems to affect it (still runs hot). Also, vacuum stays below 10" at idle no matter where I set the timing. The question is do I need a better radiator? It currently has a 3 row stock looking setup with stock fan. Is it assumed you need a 4 core alluminum radiator when running a 383 with vintage air? Looking for advice before purchasing a Champion MC369 radiator. |
Re: 383 stroker running too hot
I think the first thing to do is to verify that the truck is actually running hot. Pick up a non contact laser thermometer and see what the truck is really doing. Check at the thermostat housing, top of the radiator and the bottom of the radiator.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD ![]() 1970 Chevy Nova - Street and Strip Project ![]() 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
20' Daredevil (Ret)
![]() Join Date: May 2003
Welcome. Seems to be a rash of running-hot threads here lately. I like Sean's idea of verifying actual temps first, as the old stock gauge -- or its sending unit -- may be off.
Other things you might check: it has a fan shroud (good) but what type of fan, and is the fan in the right location within the shroud? Good pressure cap? Coolant recovery tank can help a bit since it allows the radiator to stay full.
In your picture there is a gap between your radiator and condenser.....seems like ambient engine air/temp is or would be getting pulled back through instead of pull through the condenser to help pull down the temp.....how is the a/c doing cooling the interior?
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
Sean, I have a laser thermometer now. It's only 87 degrees outside right now (and the stock gauge is now only going 2/3 way) so obviously my measurements are showing cooler. Therm housing is 220, top of radiator is 219, bottom of radiator is 192. I need to measure during the heat of the day tomorrow when it should be 100.
Stocker, The fan blades are positioned half way within the shroud. It's a 7 blade clutch type fan and pulls air into the engine area. Pressure cap is 14psi. I haven't been losing coolant so not sure an overflow tank would help? See attached picture. Run GMC, the AC is working well until the engine gets too hot and everything starts to bake. |
Might have to "Burp" your cooling system, air pockets can get trapped in the heads causing the engine to run hot. Some people have drilled a 1/8" hole in their thermostat to aid in venting the air out of the heads. HTH,
Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
20' Daredevil (Ret)
That all looks / sounds good. Maybe the fan clutch isn't doing its job well enough, possibly being stressed by the new stroker. Also just might need a different radiator as you first thought. Gonna be interesting to see what readings you get when in tomorrow's heat.
Snipescastle2, I've read about drilling that 1/8" hole many times on other posts. Any reason not to do it? If not, I'll try that soon.
Stocker, is there any way to test a fan clutch? Or do you just replace them when you suspect a problem? |
#9 | |
20' Daredevil (Ret)
http://www.aa1car.com/library/cooling_fan_clutch.htm http://www.haydenauto.com/featured%2...s/content.aspx Note the differences in design (thermal / non-thermal -- always go with thermal), and standard duty, heavy duty, and severe duty thermal units. Aside from possibly being worn out, you may have a standard duty unit and your 383 might be happier with a heavy duty. Looks like severe duty is only needed on larger trucks, or ones that are working extra hard and need even more aggressive cooling.
OK, update: Ran it again at 95 degrees outside. Therm housing was 232, top of radiator 228, and bottom radiator 205. Seemed like it was headed higher too before I shut it down. It's definitely hot, and it sounds like fuel boiling in the edelbrock 1406 carb after shut down.
Also did the fan clutch spin test. Almost 2 turns while cold, then about 1 1/4 turns while hot. So fan might be a little marginal according to the links Stocker sent me yesterday. |
Sounds like you need a new fan clutch.
Also what type heads do you have? Vortec and some aftermarket heads don't have a place for the by-pass on the water pump. You need a bypass hose from the front of the intake to the top of the water pump. |
#12 | |
20' Daredevil (Ret)
Your fan looks like mine, with a 2 1/2" pitch. Per the Hayden site that requires a heavy duty unit.
#13 |
Yes about 1 1/4 full turns freewheeling (with good effort to spin it) while it is still warm. That AA1car.com website showed 1 to 1 1/2 turns was acceptable. Am I mis-understanding it? If I need to replace, how is that NAPA fan clutch working out (from other thread). Part # 271303. That would be much easier/cheaper than replacing my radiator.
Gary1961, I don't know what I have for heads. Sorry, I'm lacking both experience and information about this engine. Is there any way to tell right now while it's assembled? The intake is a Holley contender. There is currently a heater hose and the main coolant return to the radiator. No other hoses. See attached photo. |
#14 | |
20' Daredevil (Ret)
I haven't installed the new NAPA unit yet. I just bought it today and the weather has been too hot to wrench on anything unless it's an emergency..... and it isn't. You're right though, it's a lot cheaper than a new radiator. I paid $51 & change. ![]()
#15 |
Ok, I'll replace fan clutch with heavy duty tomorrow. Looks like NAPA has it in stock. Hopefully it will fit the same. Thanks.
#16 |
20' Daredevil (Ret)
FWIW, I always compare old to new, just to be sure. With my old one still on the truck, we compared measurements of the one I bought to the one they say I need (it was a standard duty, though) and all measurements & bolt patterns were the same. You shouldn't have any problem.
#17 |
![]() Join Date: Jul 2015
Been down this road. The radiator in the last pic looks a little past its prime. Today's cooling system flushes are mostly salt based, they do little to clean rust oxide from the internals of an engine not to mention do nothing for brass and copper radiators, and heater cores.
Trying looking up a chemical on this site called oxallic acid, then flush the system with lots of water and neutralize with sodium carbonate, Arm and hammers super washing soda. I even did a little do it yourself thing using a brass schrader valve into the block so I could pressure purge and release the crud with pressurized air. You should find it on this site somewhere! Do a search! |
#18 |
I have an after market temp gauge as well as a laser thermometer and I noticed a 20* temp difference from the two when I measure temp at the thermostat housing. Someone else told me they experienced the same thing.
I think it's not the same measuring core temp vs surface temp. So if you are reading 232* at thermostat housing with the laser thermometer, the actual coolant temp is likely 20* hotter or 252*. |
#19 |
![]() Join Date: May 2013
Generally 36 is tops for timing , if you were running 41 it would sound like marbles bouncing around in the engine ,,unless,,, something else is seriously off ,, try some royal purple blue ice , it works well
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#20 |
With regards to the 1/8" hole drilled in the thermostat, I can't think of any reason not to do it, as it's not large enough to bypass the flow,and it allows air to escape freely.
I'd say the clutch fan is definitely not up to par and causing more bad than good. I'm not running a shroud on mine, (I should be) but that flex fan moves a crap load of air, and has a lot of drag on the engine, but, it's maintaining the temps. Hope you sort it out soon! Ben ![]()
#21 |
Looks like you have a 2 core radiator. Now that you have A/C I would change it to a 4 core. When I tool around in slow traffic in 100 degree heat with my Vintage Air on the temp starts moving up to 200. If I driving at 50+ it stays at 185. I have 4 core and 185 stat. Without the A/C on it stable @ 185.
1970 C10 Short Stepper with 71/72 front clip. |
#22 |
You jumped on the fan issue, which is good, but did you really look at that radiator? How old is it? They usually look worse inside, than they do outside, and just the outside looks to be past its prime. Also, you have an AC condenser, and what looks to be a trans cooler, double stacked in front of the radiator. One or the other is okay, but three is typically a no-go.
You never want your fan to have to work through anything to pull air across the core. Bent fins, dirt, trash, and mounting places like where your accumulator is attached to are all obstructions. AC condensers, and trans coolers are also obstructions if they have bent fins and trash in them. You may have created a dead spot on your radiator the size of the trans cooler, which i'd estimate at maybe 25% of your surface area. If you're lucky, the fan is the biggest culprit as it's the cheapest fix, and it sounds like it needed to be replaced anyway. However, i'd take a house fan and aim it across what you have now, and feel with your hand on the inside to find any points of weak airflow or misdirected air. The aluminum radiator covers do a good job of directing airflow through the core by eliminating the gaps between the core support and the radiator. Best of luck figuring it out! |
#23 |
Lefty, I agree about the radiator. My original thought was to replace it with a 4 core. My current radiator doesn't have a trans cooler built in, so that's why the cooler you see in the picture is there. If I install a 4 core aluminum with built in trans cooler, can I get rid of the little unit blocking my air flow? Or is it still needed in addition to the radiator for TH400 cooling? If so, another reason to upgrade to a 4 core.
In the mean time, going to install this new fan clutch which should definitely increase my air flow. If I replace the radiator, also going to drill the 1/8" hole in the thermostat at the same time. Will also re-adjust the total timing down to 36. |
#24 |
Just another thought - it looks like that fan has taken a hit or two in its lifetime. I don't know if they become dangerous when damaged, but it can't help. If you have access to a spare, replace it when you replace the clutch. Keep the same style and same or higher blade count, of course.
#25 |
Those auxiliary trans coolers are just that, auxiliary. You really want a liquid cooled heat exchanger for the transmissions heat, the air coolers help, but minimal.
Ben
