Carpe manana
![]() ![]() Join Date: Dec 2010
WTB: A.I.R. Smog pump Parts for SBC
Chasing one of the mount brackets (shown below), pump w pulley, thing that attaches to pump, and injection tubes. Could also use the manifold heat stove for the AIR system for 4wd application. Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#2 | |
Re: WTB: A.I.R. Smog pump Parts for SBC
http://sandiego.craigslist.org/esd/pts/5705027032.html |
#3 | |
Carpe manana
No worries! and thanks for the offer! I may need some help locating things from time to time. Cheers! John
![]() Join Date: Jul 2016
I think that bracket and the manifold that bolts onto the air pump could be the same as C3 corvettes, 68-82. The later model stuff is a little different but those vettes mounted the AIR pump like the one in the picture and had short water pumps to. Try the corvette parts houses, maybe Wilcox has that stuff? Could also try the corvetteforum.
Always on the hunt...
![]() Join Date: Sep 2006
Hey Pete, here are the small block smog parts that we spoke about end of last week, this stuff was removed from a very original survivor CA. 72 C10 w/350. The setup contains, both smog pump mounting brackets, pump pulley, diverter valve and both diverter valve to injection tube check valve hoses with correct OE markings and all four witek clamps. $125. plus $14. on the shipping, can combine ship the horn parts in with this stuff if needed. Again, sorry for the delay in getting this smog and horn stuff pulled out. Let us know, Mel.
Last four pics...
Man if that was for a BBC I'd be all over it!
IT IS WHAT IT IS |
#10 | |
LMK Rich
IT IS WHAT IT IS |
Carpe manana
Mel I'll take the parts thanks. Do you happen to have the smog pump I could use for a core and/or the manifold injection tube thingys? Will take the horn/harness too pending Johns reply. Thanks again. Pete
Edit: any chance you have the pulley and bracket attachment bolts? I could also use about one dozen OEM bolts to affix the front end sheetmetal like inner to outer fenders - have captured washers.
Carpe manana
Mel - John was able to set me up with the horn, thank you. I'm in for the smog equip above and and spare bolts if you have them (manifold tubes and pump as well). Pete
#13 | |
#14 |
Carpe manana
Payment sent - thanks again Mel
#15 |
Pete, your a.i.r./smog parts are under way, the package went out USPS priority insured on Thur. 08/18, the projected delivery date listed on the postal receipt is Sat. 08/20. We stuck a few extra non-requested front end specialty bolts in with your shipment. Thanks again for the repeat business, Mel.
