Old 08-15-2016, 05:24 PM   #1
barry1982
Rear Brake Lines
Hi Guys..... I'm still tinkering with my old 82. Noticed the metal brake line running along the frame on passenger side looks very rusty in spots. Have any of you guys replaced this line? Does someone sell with correct bends, or do you fab your own? I see Classic Ind sells the lines over the rear diff.....but did not see the frame line.
barry1982 is offline   Reply With Quote
Old 08-15-2016, 06:58 PM   #2
Nick_R_23
Nick_R_23's Avatar
Re: Rear Brake Lines
I make my own, but most of the classic parts sites should have prebent lines. Napa usually carries lengths of straight line with ends already on them.
Old 08-16-2016, 09:14 AM   #3
Shugalou
Shugalou's Avatar
I made my own and it wasn't too bad at all to do.
It might be tuff to find a length that long that already has the ends as it was probably close to 8-10 feet. I bought a roll of line from NAPA and put tape on the ends while I was checking and re checking.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 08-16-2016, 12:38 PM   #4
GRX
GRX's Avatar
NiCopp (nickle/copper) line is extremely easy to bend & flare. Comes in coils and a trick is to roll the length between two pieces of plywood to straighten - where needed.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-16-2016, 02:28 PM   #5
Shugalou
Shugalou's Avatar
While you are in there you might want to replace the rear flex line if it has been a long time. I upgraded to stainless Russell lines when i rebuilt my entire system...if you have any hang ups search my threads on brakes as many members offered great advice and helped me through a couple of hick ups.
