Old 08-16-2016, 09:22 AM   #1
GOPAPA
GOPAPA's Avatar
Brush and Spring ,,You Tell Me What Happened
My truck (1971 350 )
I was out for a fun drive last week and came home parked the truck in the garage , it ran just fine and has been running great for ever.., it has always started up right off the get go .no sound like rrrrrrrrrrr rrrrrrr rrrrrrr ,,it's been a fast starter since day one..
Anyway I decided to put new plugs in and also a new fuel pump ,,plugs was about time and fuel pump was just for good measure as their life span is ,,you never know..
so ,after the installing of these two things I went to crank it over and "NOTHING" whole bunch of rrrrr rrrrr rrrrr and no quick start ,, I thought ,,darn bad fuel pump,, so checked if there was gas coming thru the line and into the carb ,,yep two good squirts there,,
So next to see if it had fire at the plugs ,, "nope" none there,, next a test to see if the coil was bad,, what i did here was replace it with a brand new one that I have had for a few years that i had for my 72 that I sold , Still no Juice to the plugs.. Just about out of ideas ..and then I decided to look a little deeper and I found that the brush spring was not pushing the brush down deep enough to make contact,,,
I have never had a brush spring get soft before ,,have you? I had to leave the rubber washer out after I stretched the spring out to make it reach ,, put it back together and it cranked right up.
I went and got a new brush and spring and washer and the guy at the parts house told me that in his 8 years he has never sold these parts by them self .only the whole distributor...
So,, any ideas what made the spring get that weak and not reach ?
Sorry next time I will down size
[IMG][/IMG]
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 08-16-2016, 09:27 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Brush and Spring ,,You Tell Me What Happened
Yup mine did something like that. It was just after a bad accident and I think the cab hit the distributor.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-16-2016, 09:57 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Was the spring discolored like it might have been overheated? I've never had that happen myself.
LockDoc
Leon
Old 08-16-2016, 10:19 AM   #4
GOPAPA
GOPAPA's Avatar
LockDoc
I just went and looked at the spring Leon and it is dark colored ,,but not burnt and it still has some kick to it as for spring ,,it is not shiny like the new one but being in where it was ,,it gets discolored anyway I think.. I did use a q-tip and cleaned very little lead dust up from the brush ,,but it was minimal ..
The brass plate thingy in the bottom was also bent a little and I straightened it out with needle nose,, so it got hung up it seems ,,but why and how?
Old 08-16-2016, 12:32 PM   #5
72kool
72kool's Avatar
funny story about those parts. ive had some issues in the past with old parts going bad and just 40 year maintenance. about 4 years ago i did the HEI swap. what a difference that made in performance! long story short, about two years ago i was having issues and pulled the cap and realized after its last tune up, i didnt put the brush and spring in the cap! never noticed in the performance at all. thats a hot distributor! goes to show how much parts can differ from each other and how lucky i was.
1972 GMC C20 Custom Camper 350/TH350
72kool is offline   Reply With Quote
Old 08-16-2016, 01:05 PM   #6
midniteblues
midniteblues's Avatar
you could pull the distrubuter and check the end play of the gear.it could be way outa spec. Pushing up on the rotor when the engine is running.
Exsessive cam walk could also be the culprit.
You could check the lift of the rotor by slighty turning the crank pulley back and forth with the cap off.
The plates in the distributer that the wieghts are on are only pressed onto the shaft they are also splined. but could possibly lifted up somehow.(highly unlikely)
Your arc marks should be about centered on the cap contacts.
My vote is cheap spring wire or poor engine grounding or the ground strap for the coil causing resistence.
I noticed lately with distributer caps the quality has gone way down.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 08-16-2016, 01:12 PM   #7
tdangle
tdangle's Avatar
Over the years, I have seen this happen to a couple of vehicles I've owned. As a interesting story, Years ago, I was on vacation visiting my Father on the east coast and he was telling me about his carpool van (GMC) that just was not running right. He had it in the shop a couple of times and although they kept charging him to "fix it", It still didn't run well. I opened up the HEI cap and found the center button/spring was pretty much melted. Put a new cap and rotor on it and the van ran great.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 08-16-2016, 01:52 PM   #8
leftybass209
leftybass209's Avatar
Weak springs and heat, can cause a lot of headaches. That stuff can get easily bound up too on cheap parts. Pretty damn good diagnosing skills to find that was your issue.
leftybass209 is offline   Reply With Quote
Old 08-16-2016, 01:54 PM   #9
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a very good tutorial on rebuilding the distributor.
http://www.rustpuppy.org/ignition2/Ignition%202b.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-16-2016, 09:57 PM   #10
GOPAPA
GOPAPA's Avatar
Hello,, been awhile ,,you sure know your wiring ,, That is a good 101 for rebuiding a Distributor... I will remember you if I need some wiring tips ,, thx
