What transmission is this and what's it worth?
Pulled this from my 68 2WD Suburban.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
Re: What transmission is this and what's it worth?
Got to be worth $100 right?
1982 K10 SWB 1987 V20 - Sold - Doh! |
It appears to have an aluminum top cover - if so it's an NP435. Most prevalent in Fords, but I believe it was called the "close ratio" option on late 60's Chevys. My Suburban has one in it, though not original. Can you snap a shot of the ID tag? I'd like to compare numbers to mine - haven't found any decoding info for them yet.
And yes, I have to think it'd be worth $100 if it's functional.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
The Older Generation
Here is a picture of the different transmissions. Not all for our trucks of course..... LockDoc
#5 | |
Suburban. Paul
It's worth what someone will pay, but I wouldn't pay more than a $100 bill for it. There's just too many inexpensive newer options out there.
Rock n mud guys may have some interest. |
Thanks. Here's mine:
![]() The first characters on the second line sure look like a date code, followed by "435" to denote model, I suppose.
![]() Join Date: Mar 2003
Did your 'burb have a big block? I have a 68 truck with a big block with a different serial number, my first gear is 4-1
#9 | |
No this transmission was behind a 292 6. What other vehicles can this transmission go in? Did cars use it? Paul
So your first gear is a 'granny gear' 6-1 Trucks only, I think this was a 4 speed the GM used with the transition in 68 from the SM420 to the SM465
No, no cars equipped with it from the factory. Some Chevy trucks, more Fords. Don't think Jeep, Dodge, or IH ever used it. It's right in there with the GM SM420/SM465, and Warner T18/19. Considered obsolete to most because of the lack of an overdrive, but well suited to heavy duty 4x4 builds. Even big block engines have to get pretty brawny before they test the limits of it.
