Old 08-16-2016, 02:46 PM   #1
Marshy
Room to Drop the Oil Pan?
Anyone know if there is enough room to drop the oil pan in a '84 K10 with the engine in place?
Long story short is I have to retrieve something that fell and landed on my windage tray. That mean the pan must come off.
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15
GM 4 bolt 880 roller block, 062 Vortec Heads
Comp Cams XR258HR-10, MSD Street Fighter HEI
Edelbrock: Performer Intake 2116, 1405 Carb
Long tube headers, 2.5" duals to Flow Master Super 40's
Vortec Engine Build
Marshy is offline   Reply With Quote
Old 08-16-2016, 03:27 PM   #2
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Re: Room to Drop the Oil Pan?
Yes, plenty of room.
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 08-16-2016, 03:29 PM   #3
Marshy
That's good news.
Can I reuse the pan gasket? Its the blue rubber type from fel-pro. I assume I cant because of the gasket maker in the corners..?
Vortec Engine Build
Old 08-16-2016, 04:19 PM   #4
Mr.Chevy4x4
If it's the one piece style and still in good shape you probably could get away with it. Make sure to put a little rtv in the corner areas where leaks are common.
Mike
Old 08-16-2016, 04:34 PM   #5
Marshy
Thanks. It is a 1 piece.
Vortec Engine Build
Old 08-16-2016, 11:33 PM   #6
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: Room to Drop the Oil Pan?
make sure you clean all the oil off of it. maybe with some dish soap. i used some paper towels then a dry rag when i reused mine. i also picked at the gasket maker that i had put in the corners till i got it all off. a little time consuming but worth it
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 08-16-2016, 11:39 PM   #7
Marshy
It seems I got lucky (I use that term loosely) because the gasket stayed well adhered to the engine block. I'll make sure the gasket is oil free when I assemble it.
Only issue I can see is the oil pump pickup was in the bottom of the pan when I took the pan off. Maybe I knocked it off when I pulled the pan down..? Is it possible it fell off before I removed the pan? EEEK!
Vortec Engine Build
Old 08-17-2016, 06:52 AM   #8
77 ChevySport
Marshy: Yes it is possible as it is only a "press fit" from the factory. Many engine builders braze the pickup to the pump. (I did this for safety on my 77 Sport) LS9. Larry
Name:  braze pickup.jpg
77 ChevySport is offline   Reply With Quote
Old 08-17-2016, 08:30 AM   #9
Marshy
Well, I slipped it back on. I hope it stays put. It was a new oil pump but reused the pick-up. IDK why they didn't just make it with a 5* taper so it locks tight.
Thanks for the comments guys. Fishing went well and I retrieved the dropped item. I wiped out the bottom of the pan and lightly wiped the seal down with some brake Kleen on a rag. Everything slid into place.
Vortec Engine Build
Old 08-17-2016, 08:48 AM   #10
Mr.Chevy4x4
They make a little bracket that clamps on the pick-up tube and bolts to the oil pump. I would at least do that. If the pick-up comes back out while you are driving you will have zero oil pressure, and serious damage.
Mike
Old 08-17-2016, 08:54 AM   #11
Marshy
I will call my parts store and see if they have anything like what you described. The pan is back on but no oil in it. It could come off easily. I keep a close eye on my oil psi and it was acting fine before I removed the pan.
Vortec Engine Build
Old 08-17-2016, 09:03 AM   #12
Mr.Chevy4x4
Like this:
https://www.summitracing.com/parts/p...FdVbhgodJ2gHLQ
Mike
