bleeding brakes 1 side no fluid???
71 K10 going through the steps of bleeding the brakes start at the back pass side, then i go over to the drivers side and no fluid????? just to add to this i took the whole bleeder out to see if it would come and still nothing. what do i do next? is it the caliper?
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: bleeding brakes 1 side no fluid???
Unless the rear brakes have been converted to discs, there are wheel cylinders back there -- not calipers. At any rate, the rear brakes share a single line to the differential. A T-fitting splits to a hard line to each side. You had fluid to the passenger side so the problem is between the T-fitting and the drivers side brake. Try disconnecting the hard line where it goes into the wheel cylinder (or caliper, if discs). If you have fluid there, the problem is within the wheel cylinder (or caliper). This assumes there is still adequate fluid in the master cylinder. Any chance it ran dry after bleeding the pass. side?
right sorry. thanx for that. i do have drum brakes so yes no calipers. cool i will check the line at the T sounds good thanx for the help.
