Old 08-17-2016, 12:39 AM   #1
thedudeabides86
Active Member
thedudeabides86's Avatar
Oil dipstick port problem
I have a silly problem. I had a poopy 305 in my '72 Chevy 3/4 ton and pulled it for a used, strong 350. The 305 had no recessed shoulder in the dipstick port and the 350 does. This shoulder that is recessed blocks me from getting the dipstick properly inserted into the block. I'm trying to get this truck running before the Gearhead Get Together in Maple Lake, MN on Saturday. www.gear-headgettogether.com
Anywho, I'd really rather not have a mundane issue like this slow me down. I really need help in figuring out what I need to do to remedy the situation. Thanks in advance! See picture below of said recessed shoulder.
The Dude abides.
thedudeabides86 is offline   Reply With Quote
Old 08-17-2016, 06:39 AM   #2
haysonj
haysonj's Avatar
Re: Oil dipstick port problem
Different years and different applications took different tubes. You need to know what year the block is and whether it came from a car, truck,or van. You could go get a universal one from the auto parts store. Some motors also had a lower tube in them to guide the dipstick past the crankshaft.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-17-2016, 09:51 AM   #3
thedudeabides86
Active Member
Thanks! The 305 that was in there was a '79 motor out of a G series van. The engine ID number on this 350 throws me off as it starts with a "C4F4" and I can't decipher it. Anyway I could plug the dipstick port whilst driving it and make due?
The Dude abides.
Old 08-17-2016, 10:10 AM   #4
B. W.
B. W.'s Avatar
If your 305 dipstick location is the same as your 350 (in other words, it doesn't enter through the side of the pan)you can measure the depth of the recessed shoulder & cut you 305 dipstick to fit. I like to use "avaition form-a-gasket" to help seal it & hold it in place. the 305 stick may not read correctly but you can scribe a mark on it for "full".
B. W. is offline   Reply With Quote
Old 08-17-2016, 10:30 AM   #5
thedudeabides86
Active Member
Cutting the dipstick may not make a difference as it'll still hit the shoulder in the port of the hole. I think my best solution will be to taper the gooseneck for the dipstick to get past the shoulder.
The Dude abides.
Old 08-17-2016, 10:44 AM   #6
68is4me
68is4me's Avatar
That car show looks like fun. In that add I have seen a lot of those cars at the ST. Peter show. Do they have a swap meet too? never mind I seen they do.
As for your tube, that looks like it requires the 2 piece tube's. Should be a lower one the goes in the block and then a upper tube. I think these are the correct pictures of how they should look.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 08-17-2016, 11:20 AM   #7
Bigdav160
Bigdav160's Avatar
Those pics look correct, the one on the left goes in the hole first and driven in. It keeps the dipstick away from the crankshaft. Then the upper tube gets driven in. Use an open end wrench on the shoulder to pound on.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-17-2016, 11:59 AM   #8
thedudeabides86
Active Member
Gotcha, that might be the solution. What's the technical term for that piece on the left if I wanted to order something from Oreilly or Napa?
The Dude abides.
Old 08-17-2016, 12:15 PM   #9
thedudeabides86
Active Member
I found that part on Summit. Thanks for all your help guys. I really appreciate it.
The Dude abides.
Old 08-17-2016, 05:23 PM   #10
Big Kev-O
Big Kev-O's Avatar
Man I love this site. My dipstick hits a crank cap stud and will not go down no matter how I bend the end. Looks like I'm missing that lower tube that guides the stick. I hope this fixes my issue too. I have a feeing it will. Thanks guys.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 08-22-2016, 02:28 PM   #11
thedudeabides86
Active Member
So, I got this part in today. I imagine I just push this down into the port hole and that it'll seat right at the surface of the block allowing the dipstick to bypass the shoulder down below? Will this change my reading on the dipstick of the oil level? I only ask because once I open it, I can't return it, of course.
The Dude abides.
Old 08-22-2016, 03:43 PM   #12
68is4me
68is4me's Avatar
Yes, it should be a fairly snug fit. I sometimes take an open end wrench that fits above the collar of the tube, and tap the wrench with a hammer. I also smear a little RTV sealant on the tube. Not sure on the dipstick. Can you compare the old tube to the new? If they are the same length you might be ok.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
Old 08-23-2016, 11:02 AM   #13
thedudeabides86
Active Member
So, this feeder tube doesn't seat entirely into the block, correct? This would replace the existing dipstick tube and help bypass the shoulder? Forgive me with my "rookie ways" as I'm learning as I go with all this stuff. Thanks for having patience with me.
The Dude abides.
Old 08-23-2016, 12:22 PM   #14
70STOVEBOLT
70STOVEBOLT's Avatar
The lower tube goes into the block and seats against that shoulder. It will be a tight fit. The upper tube goes in next and seats against the lower tube. It will fit tight, but probably not as tight as the lower tube.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 08-23-2016, 01:12 PM   #15
68is4me
68is4me's Avatar
Looking at you pic again, and you might already have the lower tube in the block already. Did you buy both tubes? If you did try lower 1st, and if it doesn't go don't force it. Then install upper tube.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
Old 08-24-2016, 09:52 AM   #16
thedudeabides86
Active Member
Good morning. I bought the lower tube on Summit but haven't opened it since I can't return it if I do. I have the old upper tube from the 305 and when I drop that into the hole (on the 350) it slides right in, but not deep enough for the dipstick to pass by the shoulder without getting caught. I'm going to try tonight to tap the old dipstick tube down enough to seat against the shoulder and hopefully that will solve my problem. My other major problem is that I have no power whatsoever when I go to turn over the motor. No headlights, horn, nothing. I'm going to create a separate post to address this no power issue and see if anyone can suggest anything. I'll keep you posted.
The Dude abides.
Old 09-06-2016, 08:38 PM   #17
68is4me
68is4me's Avatar
Did you get your dipstick figured out?
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
