WTB: Rear Upper Spring Perch Mounts
Looking for a set (left and right) of the rear upper spring mount perches. These are the brackets on the underside of the rear shock crossmember that attach the crossmember to the frame. Anyone parting out a frame?
Shipping to 45431 Thanks!
1971 Chevy C-10 Currently is rust repair |
Re: WTB: Rear Upper Spring Perch Mounts
These are off leaf spring truck or are you looking for trailing arm truck mounts
My truck is coil spring..not sure if leaf has these as well.
These z shaped brackets are what I'm looking for...they attach the shock crossmember to the frame from below (riveted to frame and crossmember) Mine are no longer solid and are bent out of flat from corrosion between them and frame ![]()
#4 | |
