Old 08-17-2016, 11:07 AM   #1
superdav
Does anybody make -2 inch spindles for 1 inch rotors?
Or do I have to convert to heavy duty brakes?
superdav is offline   Reply With Quote
Old 08-17-2016, 11:17 AM   #2
JWall
Frequent Flyer
JWall's Avatar
Re: Does anybody make -2 inch spindles for 1 inch rotors?
I thought BellTech did but they offer a 3" spindle for a 1" rotor...
http://www.belltech.com/products/bel...set-14013.html
- Justin
1 Owner 1976 SWB
Old 08-17-2016, 11:28 AM   #3
ultrahd4me
ultrahd4me's Avatar
No 2" modular spindles for 1" rotors, but several options for 2-1/2" or 3" drop spindles.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 08-17-2016, 05:42 PM   #4
superdav
Im ready to order a bunch of parts
I want a 2/2 drop and I could care less which brakes but I really don't want to have to swap everything over. The truck has calipers and rotors that don't have many miles on them and I don't know what has to be swapped on the rear for brakes. Ill have to look into it but even the brake hoses have different part numbers.
I found 1 set this morning but I can't find them again. I should have saved a link but the amazon ad didn't look very professional
Old 08-17-2016, 06:02 PM   #5
ultrahd4me
ultrahd4me's Avatar
If I'm understanding your post correctly, you're want a 2" drop front and rear. If so, I would keep your stock spindle and go with a 2" drop spring up front, and a 2" lowering shackle on the rear. Summit racing will have everything you need. Another cheap option is to cut one round off your stock coils and you will get about 2" of drop also.
Old 08-17-2016, 06:42 PM   #6
superdav
That is exactly what I want, I want to keep the rake. I've been told by some not to use springs but as I've never lowered any of my trucks so I only know what others tell me about lowering but now the springs seem to be the best choice
Old 08-17-2016, 06:56 PM   #7
bbbc10
Diggin The SquareLife
Go with spindles over springs always.....spindles will lower your body an springs will lower your suspension....an jus get some 2" shackles for the rear
bbbc10 is offline   Reply With Quote
Old 08-18-2016, 12:59 PM   #8
MalibuSSwagon
Western Chassis has 2.5" drop spindles for 1" rotors.
MalibuSSwagon is offline   Reply With Quote
