Old 08-17-2016, 04:18 PM   #1
noslowboww
Dropped nozzle inside gas tank
So I was putting gas in my truck with a 5 gallon container and the nozzle fell out of the container and down inside my gas tank. It's still the original tank behind my seat. Any suggestions?? Has this happened to anyone else before? The truck is still running fine but I don't like the thought of something being down in my gas tank.
noslowboww is offline   Reply With Quote
Old 08-17-2016, 04:21 PM   #2
davepl
davepl's Avatar
Re: Dropped nozzle inside gas tank
You could likely leave it there forever and it would never cause a problem, unless I suppose it got hung up in the float arm.
You might want to try one of those flexible "claw" grabbers. That's about the only way I can think of, and that's going to be poking in the dark hoping for a lucky grab....
Before you do anything with anything, ground yourself and the tool. You don't want sparks.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-17-2016, 05:16 PM   #3
68is4me
68is4me's Avatar
I wouldn't worry to much about it.
You could run the tank as low as possible. Theb take the sender out, have a helper shine a light through the filler hole, and like davepl said use a claw and try to grab it.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 08-17-2016, 05:24 PM   #4
tommys72
tommys72's Avatar
Use a grabber but you need good light...use a road flare.
Just kidding of course. Like 68 said, run her close to empty and use a light. Kinda fish around.
Then id get rid of that can and nozzle, my nozzle has a bend at the end. I couldn't force it all the way in the tank if i tried
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 08-17-2016, 06:30 PM   #5
Tuff Gong
Tuff Gong's Avatar
Is the nozzle plastic or metal? If its plastic does it float? If it floats you might not what to chase it down with an empty tank. If its metal can you use a strong magnet to bring it to the top. Just throwing stuff out for thought.
Tuff Gong is offline   Reply With Quote
Old 08-17-2016, 08:00 PM   #6
noslowboww
So the nozzle is plastic and its also hollow so im assuming that it has sunk to the bottom of the tank. I was just worried about it getting stuck to my float arm or doing something to my sending unit. I'm thinking if I take out the sending unit I should be able to see pretty well down inside the tank with a good light. Or I could just toss the whole tank and buy one that goes under the bed. I've needed to do that for a while. I hate how the tank is literally right up against my back. So much wasted space.
Old 08-17-2016, 08:05 PM   #7
garyd1961
Try parking a hill with the filler tube facing down hill and shake the truck really hard. Then try fishing it out.
garyd1961 is offline   Reply With Quote
Old 08-17-2016, 10:24 PM   #8
Dustmaker65
Dustmaker65's Avatar
LOL.....take gas cap off and roll truck over a couple times.
Oh wait! We can't be putting gas on the ground!
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 08-17-2016, 10:50 PM   #9
snipescastle2
snipescastle2's Avatar
I have one of those grabber tools that was mentioned except mine has a LED light in the center of the "claws" so you can see what you're going after. Let me know if you want to use it, for the cost of shipping to and from, I have no problems loaning it to you, as long as I get it back in a reasonable timeframe.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 08-18-2016, 11:59 AM   #10
noslowboww
Man that would be awesome. I'd really appreciate it. I could definitely get it back to you asap
Old 08-18-2016, 12:01 PM   #11
snipescastle2
Send me your address via PM and I'll send it out tomorrow/the next day
Ben
Old 08-18-2016, 12:09 PM   #12
SIXTY9
Is the light chemical proof? The gas might destroy the light.Posted via Mobile Device
SIXTY9 is offline   Reply With Quote
Old 08-18-2016, 09:48 PM   #13
snipescastle2
Talking Re: Dropped nozzle inside gas tank
I've used it with oils and solvents before shouldn't be a problem.
Ben
Old 08-18-2016, 09:54 PM   #14
garyd1961
I don't see what's so funny. You can't get to it if it's on the passenger side of the tank.
Old 08-19-2016, 02:21 AM   #15
toolboxchev
Run the truck empty, remove the sending unit, get a coat hanger wire and FISH. you could even wrap some duck tape on the end and pull that thing out no problem.
toolboxchev is offline   Reply With Quote
Old 08-19-2016, 06:11 AM   #16
finewayne
nice mehtod man, it's tricky
finewayne is offline   Reply With Quote
Old 08-19-2016, 11:32 PM   #17
toolboxchev
Its all about the cost!
Old 08-21-2016, 12:11 PM   #18
midniteblues
midniteblues's Avatar
There was one of them in the tank of
my k20 when i pulled it. The tank was trash anyway though.
If its one of the straight through nozzles i would see if it fit any other gas cans you have. These new style ones are JUNK!
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
