Old 08-17-2016, 04:34 PM   #1
forestb
forestb's Avatar
glew in door seals or buy new ones
I bought a set of Steel Rubber Products door seals and they do not stay in place. I am trying to figure out if I should get another brand, (thinking of going the honda civic wrought), or try to use some kind of gasket glue to hold them in place. The doors shut pretty good with the seals that are on there now, that is when they are in place, so that is not an issue.
forestb is offline   Reply With Quote
Old 08-17-2016, 06:45 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: glew in door seals or buy new ones
Years ago when I replaced my door seals on my 65, I seem to remember using some kind of glue.
If the new ones you have now seal good, what's your concern about just gluing them?
I did buy the civic ones, but I haven't tried them on yet.
http://67-72chevytrucks.com/vboard/s...d.php?t=617703
66 C20 Service Truck:
Old 08-17-2016, 06:51 PM   #3
forestb
forestb's Avatar
I heard some complaining in another thread about trying to get the gasket off after it had been glued on and wishing they had done it differently.
Old 08-17-2016, 09:12 PM   #4
jocko
jocko's Avatar
recommend look into Dodge Dakota door seals - some folks on here seem to swear by them. Google on this site and you'd find some info.
Old 08-19-2016, 02:53 PM   #5
Joemomma1
Joemomma1's Avatar
Just glue them. How often do you plan on removing them?
Joemomma1 is offline   Reply With Quote
Old 08-19-2016, 03:28 PM   #6
jason999
I bought the Civic door seals that have been talked about on this forum. I couldn't find them used, so I ordered from a Honda dealer. I think I paid $85 or so. They weren't cheap but they fit perfectly!
I was reluctant to spend the money but I'm glad I did. I highly recommend them. If you need more information or can't find the old thread, I'll be glad to help you.
Also, the internet dealer that I used was the cheapest I could find. Local they were over $100.
jason999 is offline   Reply With Quote
Old 08-19-2016, 04:18 PM   #7
MalibuSSwagon
3M Super Weatherstrip adhesive is usually the stuff to use. Like said, if they fit and your only issue is they don't stay in place, whats the harm in gluing them on?
MalibuSSwagon is offline   Reply With Quote
Old 08-19-2016, 05:37 PM   #8
AnotherWs6
AnotherWs6's Avatar
Mine don't even remotely stay in place. PO may as well just used grease instead of glue.
What year civic do you buy? One Civic door will do one truck door?
1968 C-10 Suburban - Original 396/TH400
2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen
2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck
2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have.
AnotherWs6 is offline   Reply With Quote
Old 08-20-2016, 02:21 PM   #9
Kenfuzed
Kenfuzed's Avatar
I agree, if they fit and just need help staying in place just glue them with the 3M adhesive and save yourself some money. The Civic seals are great but I wouldn't say they fit any better than ones that require some glue. Unless you plan on constantly removing them if your truck is going through various states of restoration then a little bit of glue is the way to go.
If you do decide to go the Honda route there is a thread on it somewhere here. Just be sure to read through the whole thread since I found there was a part number correction noted half way through.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 08-20-2016, 02:35 PM   #10
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by Kenfuzed View Post
...If you do decide to go the Honda route there is a thread on it somewhere here. ...
Post #2 Above.
Old 08-20-2016, 03:28 PM   #11
Joemomma1
Joemomma1's Avatar
There are two types of 3M adhesive that you can buy with similar item numbers. Verify with Steele which number to use. I learned that the hard way but can't remember which one was correct. That Honda seal is really Mickey mouse stuff. Don't do it.
Old 08-20-2016, 09:18 PM   #12
Kenfuzed
Kenfuzed's Avatar
Originally Posted by The Rocknrod View Post
Post #2 Above.
Ah yes, if it were a snake it would have bit me
Enjoying the ride!
Old 08-20-2016, 11:02 PM   #13
Blue666(2)
Sir, Please explain your comment on the Honda seals. I have used the glue on seals & thought they were an absolute waste of time & money. I ended up using screws & washers to keep them in place. I'll be done with my cab soon & was about to pull the trigger on the Honda seals.
Thanks,
Blue666(2) is offline   Reply With Quote
Old 08-21-2016, 12:20 AM   #14
CRUZN66
CRUZN66's Avatar
I just this past Thursday pulled off the glue on type and replaced them with press on that I ordered from Classic Parts part number 03-013B - (1960-66) Press On Door Rubber Seals - On Cab - pair $49.95. They fit the cab so perfect I would never mess with the glue on!
Rope
CRUZN66 is offline   Reply With Quote
Old 08-22-2016, 11:45 PM   #15
Joemomma1
Joemomma1's Avatar
Thanks,
The one corner that has a formed angle and the extra lip that's visible from the inside. You don't have to agree but that's what I think when I see stuff like that.
Old 08-22-2016, 11:50 PM   #16
CRUZN66
CRUZN66's Avatar
Rope
Here's a picture that shows how good they fit!
Old 08-23-2016, 11:45 AM   #17
forestb
forestb's Avatar
It is interesting that they list them for 60-66 did you have to shorten them to fit your 64-66? I am just asking because the 60-63's need to be longer.
Old 08-23-2016, 12:34 PM   #18
CRUZN66
CRUZN66's Avatar
Yes, I cut off about 10 inches on my 66.
