Will this radiator support work on my 87?
I found this 1985 with a solid core support. Will this work as a replacement for my 87? My truck has two headlights and a parking light. This truck has one headlight and a parking light.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
#2 | |
Re: Will this radiator support work on my 87?
Quad lights with quad core support. So if your truck has the same amount of lights it should work. I did have an uncle that cut into the core support to put in a quad headlight grille. I never thought it look good |
Here is my truck. Sounds like it won't work. What confused me is aftermarket supports say they fit 81-87.
Now, it will work if you want to change your quad light to dual.
On another note... That looks like a sweet ride. |
Thank you. It's a good truck, but has gotten very rusty over the past few years. We are in the process of replacing rockers, cab corners, fenders, and maybe doors.
| Bookmarks |
