Old 08-17-2016, 08:59 PM   #1
67-72lover
71 72 brake lines
can anyone tell me what the diffrence is between the four wheel drive long bed rear brake lines for 71 and 72 please
Thasks
Eric
67-72lover is offline   Reply With Quote
Old 08-17-2016, 09:23 PM   #2
Low69CST
Re: 71 72 brake lines
I don't believe there is a difference.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 08-18-2016, 11:15 AM   #3
67-72lover
That's what I thought but if you go in the lmc catalog and look at the brake lines the back three lines have different part numbers from 71 to 72 and I cant figure out the difference in them
Old 08-18-2016, 11:32 AM   #4
jr1000yarder
from what I know it's where the "t" is mounted on the axle.....On the Dif or on the Axle tube
IT IS WHAT IT IS
jr1000yarder is offline   Reply With Quote
Old 08-18-2016, 08:49 PM   #5
Low69CST
I thought the same, but I thought the hardline connected to the flex line at the same hole in the frame, regardless if it's a 71 or 72.
Old 08-18-2016, 08:54 PM   #6
jr1000yarder
I believe that is correct
IT IS WHAT IT IS
Old 08-18-2016, 11:28 PM   #7
67c10rustbuket
67c10rustbuket's Avatar
In 72 the hardline came across onto the cross member behind the axle about center like pictured in post 7 of the linked thread. The hose drops from a tab formed in the center of the crossmember. The bracket for the other end of the hose was mounted on the differential. 1967-71 had the hardline end right where the crossmember meets the passenger side frame rail and the hose bracket was welded to the axle tube between the diff and pass brake drum.
http://67-72chevytrucks.com/vboard/s....php?p=5153030
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
