Old 08-19-2016, 11:54 AM   #1
jturner18
Double fan pulley
Does anyone know a part number or where to get a double fan pulley for a 250? I just ordered my PS pump bracket so now I need a double fan pulley. What ya got? Thanks for any input.
jturner18 is offline   Reply With Quote
Old 08-19-2016, 05:47 PM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: Double fan pulley
If I remember right I used a chrome sbc pulley on my 292. I will get you a part number when I get home from work.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-19-2016, 11:05 PM   #3
andyh1956
I have one on a 250, it came from a later 70s truck I robbed the pulleys & hei from. I will see if it has a part number for you tomorrow. It is going into a Scout.
andyh1956 is offline   Reply With Quote
Old 08-20-2016, 03:01 PM   #4
paintman
got mine from LMC Truck
[/URL]
paintman is offline   Reply With Quote
Old 08-20-2016, 06:20 PM   #5
'63GENIII
'63GENIII's Avatar
[/URL]
For only having one valve cover, that engine is stinkin' cool!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-21-2016, 08:37 AM   #6
vince1
A junk yard guy told me to use one from a dodge and that they fit. It didn't without pulling the holes as I remember it but it is on there now and doing its job.
vince1 is offline   Reply With Quote
Old 08-21-2016, 12:04 PM   #7
andyh1956
OK the part # on my pulley is 354584AJ. This pulley came from a later model square body w/ HEI & integral head. The grooves are spaced 1/2" apart just like the grooves in the dampener. You should also know that the flange on the water pump was in a different location than my original pump that was on my engine when I got it so I used all three pieces. I may not be needing this stuff as the truck it's going in don't have P/S. PM me.
