Old 08-19-2016, 01:54 PM   #1
NoNeck
NoNeck's Avatar
LMC Dash Bezel or Instrument Lens Problems
Hey guys,
Has anyone had alignment problems with the LMC repro Dash Bezel or Lens? I am restoring a dash cluster with gauges and ordered both the Bezel and Lens.
Today, I started installing the new parts and immediately ran into trouble. There were the two huge extra posts in the center of the Bezel that had to be trimmed off. OK, easy enough.
Then, the new Lens was REALLY tight and barely fit into the new Bezel. I finally got it in without cracking it. So far, so good.
But, when I starting bolting the original gauge assembly into the Bezel two of the holes didn't line up. They are the two screws at the bottom next to the steering column opening. OK, maybe I can get by without using these holes.
When I flipped it over, I couldn't believe how misaligned everything was. The speedometer and gas gauge are TOO LOW in the opening. The left side of the gauges looked OK, but the little blank design and temperature wording is WAY TOO FAR to the right (looking at it straight on). The last "E" in "OIL PRESSURE" is almost under the lip of the bezel.
I know I need to make a call to LMC, but is it the repro Instrument Lens or the repro Dash Bezel? Or both?
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 08-19-2016, 02:23 PM   #2
davepl
davepl's Avatar
Re: LMC Dash Bezel or Instrument Lens Problems
That's where I got mine, and mine was the black unit (had to paint it), so I'm fairly certain I have the same one. I didn't run into any problems that I recall.
I wonder if they got a new batch or something?
Remember that you don't view the gauges straight on, and they do sit a little lower than center. How much is "normal" I can only guess.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
