08-19-2016, 04:32 PM | #1 |
Front fender bracket
I know that the front fender is supposed to have a bracket but I can't remember where it attaches. It does not hold anything on it is just for support. The bracket itself is 4-5 inches long and a little bit wider than 1 inch. Can someone post a photo of where it is supposed to go.
08-19-2016, 05:04 PM | #2 |
Check The Champ, Demonstrator
Re: Front fender bracket
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
08-19-2016, 05:08 PM | #3 |
I can't find a picture of it right now but if it's the one I'm thinking of, it goes on the top of the fender near the door and hangs out in the gap below the cowl cover.
08-19-2016, 05:17 PM | #4 |
Thank you both for your replies. The bracket is not in the exploded technical drawing and it is not the one referred to in the photo. It does not hold on a gasket. It is some kind of support bracket. I think it goes somewhere near the front of the fender.
08-19-2016, 05:46 PM | #5 |
Got a picture of it?
I don't recall anything like that going on the front of the fender when I put my front end back together. |
08-19-2016, 06:16 PM | #6 |
now that I think about it it might have been in the front of the inner fender inside the wheel well connecting to the rad support. Sorry I don't have a photo right now.
08-19-2016, 06:46 PM | #7 |
Here is a photo of the brackets that I was talking about.
08-19-2016, 07:08 PM | #8 |
Here you go.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-19-2016, 07:21 PM | #9 |
huh. That's funny I remember those being there also but I am sure there are brackets for inside the wheel well also. Now I have to look to see if those are there.
08-19-2016, 08:15 PM | #10 |
These? They are spot welded to the front and bolt though the core support. Ive got all of the front sheetmetal off of mine. If you need more pics, let me know.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
08-19-2016, 11:40 PM | #11 |
Thank you all for all of your help but I am still not seeing what I was remembering. Maybe I am not remembering correctly.
Posted via Mobile Device |
08-22-2016, 11:44 AM | #12 |
I think you are right LVPhotos. I installed those brackets in the place where that diagram shows. They fit perfect. I don't know what I was thinking of.
08-22-2016, 01:13 PM | #13 |
1965 Chevy C10, 2005 4.8L/4l60
Are you talking about the bracket on the rear of the fender that has the weatherstrip stapled to it and runs up and down on the inside of the fender? I don't have access to a pix but is that what your asking about?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-22-2016, 01:31 PM | #14 |
