Old 08-20-2016, 12:16 AM   #1
AustinBelair
I need to order a driveshaft
For an LS/4L80e install. Has anyone found a "junkyard" aluminum shaft that will work? I think late 90's to early 2000's Chevy trucks used a fat aluminum driveshaft. I thought about buying one and having it cut/balanced.
I looked at Denny's Driveshafts but I cannot afford one.
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 08-20-2016, 07:39 AM   #2
72MARIO
72MARIO's Avatar
Re: I need to order a driveshaft
I had the doner shaft from a 2003 Z71 extended cab short box cut down a little to work with my swap in the suburban. .The problem is when i jacked up the burb at droop the shaft just touched the yrailing arm crossmember. Depends on what year your building that might work for you
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-20-2016, 10:24 AM   #3
truckdude239
truckdude239's Avatar
I had my stock shaft shortened and balaced for like 60 buxs but i used olivers drive shaft shop
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-20-2016, 10:26 AM   #4
truckdude239
http://www.oliversdriveshaft.com/
David fuller
2012 Subura outback
1999 honda accord
Old 08-20-2016, 12:21 PM   #5
foamypirate
foamypirate's Avatar
If you are thinking of having one cut down, check out Scotty's Driveshaft here in Austin. They should be able to handle it, I would think. You may want to double check that they can handle aluminum though.
You may want to check with Driveshaft Specialists down in San Antonio for the price on a new one. They are pretty reasonable.
foamypirate is offline   Reply With Quote
Old 08-20-2016, 02:18 PM   #6
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I have used http://dynotechengineering.com/ several times. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 08-20-2016, 08:51 PM   #7
Keith Seymore
Keith Seymore's Avatar
Dynotech (formerly "Balance Engineering") has been around and has been used by GM for their experimental builds for a very long time.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
