Old 08-20-2016, 10:07 AM   #1
Steve Cole
Vent window restoration how to thread?
Could someone do a how to thread (or post a link to a previous one) that shows a step by step process to restoring vent windows? I'm sure many people here would be very interested in seeing the process to determine if they want to attempt this themselves. I know I would! Thanks!
Steve Cole is offline   Reply With Quote
Old 08-20-2016, 10:08 AM   #2
68bowtie
68bowtie's Avatar
Re: Vent window restoration how to thread?
ditto
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 08-20-2016, 10:53 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Does this help?
http://67-72chevytrucks.com/vboard/s...d.php?t=342167
Keith
Convert to disc brakes.
Old 08-20-2016, 10:59 AM   #4
lolife99
lolife99's Avatar
This link is from my old Project Ginger thread:
http://67-72chevytrucks.com/vboard/s...=473629&page=5
The rivet tool I purchased was worth the money.
Also I never separate the vent window hinge pin. I just remove the entire bracket from the frame and leave the hinge pin in place. (since it shows from the outside)
I also just un-rivet the top of the frame to get the rubber out.
(I take out as few rivets as possible)
Remember the order of the hardware to remove the vent window glass.
The long piece of steel in the vise makes a great holding fixture.
I did mine by myself,... but a second set of hands would be great.
Keith
Old 08-20-2016, 11:04 AM   #5
Shaky
Six in a row makes it go...
Shaky's Avatar
This is very helpful. Any information on that rivet tool? The 2011 link in your thread seems to have died.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 08-20-2016, 11:07 AM   #6
lolife99
lolife99's Avatar
http://www.zr1netregistry.com/Market...Rivett-II.aspx
http://www.zip-corvette.com/53-82-aero-rivet-tool.html
Keith
Old 08-20-2016, 11:10 AM   #7
Shaky
Shaky's Avatar
Thanks!
Old 08-20-2016, 11:11 AM   #8
lolife99
lolife99's Avatar
https://youtu.be/WiZOiHmcb_w
This video talks about removing the hinge rivet.
I do not do this.
I like to keep the look of the original rivet.
Just take the entire bracket off the frame.
(The 2 rivets on the side)
Keith
Old 08-20-2016, 08:57 PM   #9
custom10nut
custom10nut's Avatar
When you say "hinge rivet", do you mean the one on the outside? My lower pivot on my driver side seized and broke loose, so I was wondering if that is possible to repair.
custom10nut is offline   Reply With Quote
Old 08-20-2016, 09:00 PM   #10
70STOVEBOLT
70STOVEBOLT's Avatar
There is a cheap kit on eBay for I think $22 that has the rivet tools and rivets. It requires a hammer to crush the rivets but it works and if you are only doing one set of vents you don't have to spend big $ on a tool to crush the rivets. It does take a lot of time and patience. An extra set of hands would be helpful but you can do it by yourself with a bench vise. I have less than $100 in mine and that includes all the seals and felt channels, clear coat for frames, rivets and tools. I did not replace the pivot rivets though as they were still tight.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 08-20-2016, 09:09 PM   #11
custom10nut
70stovwbolt. Thanks for the info. I think I'm going to be ordering a rebuild kit soon. When I see the "rivet setter", I recognize it as the tool I used growing up on the farm, to repair broken teeth on our haybine and combine. They aren't hard to find, easy to use, and not to expensive.
Old 08-20-2016, 09:39 PM   #12
lolife99
lolife99's Avatar
Yes I mean the one on the outside.
The pivot stud on the bottom of the vent window is most often seized.
I would replace a broken assembly with a different one.
But I'm sure it could be weld repaired.
Keith
Old 08-20-2016, 10:23 PM   #13
LockDoc
The Older Generation
LockDoc's Avatar
Here is another one. You pretty much have to read the whole thread to follow it though....
http://67-72chevytrucks.com/vboard/s...d.php?t=660294
LockDoc
Leon
Old 08-20-2016, 11:56 PM   #14
Steve Cole
Wow! Thanks everyone, I knew there would be a lot of interest in this.
