Old 08-20-2016, 10:38 AM   #1
climberman
Starter wiring
My truck is finally running but we still have few problems one that is driving me crazy hahaha. Sometimes it starts and then another time you will shut it off and it won't start you just hear a click from the solenoid. The solenoid isn't pushing into the flex plate. when it is clicking If you run a wire from the battery to the solenoid it will start the truck just fine. Everything is bran new, battery, alternator is 100 amp , new regulator from summit racing , new ignition switch after market. The wire from the ignition goes straight to the solenoid am I missing something should there be a relay. I have a 1966 c10 with a 283.
Thanks for the help
Rocky
climberman is offline   Reply With Quote
Old 08-20-2016, 12:01 PM   #2
jtrichard
Re: Starter wiring
TRY another solenoid (new) sounds like it is drawing to many amps in start mode.... When you say a wire from battery to solenoid it starts. You are talking about a wire to the "S" terminal? If YES what you then have is a shorter wire with NO connections (points of resistance) and maybe a lager/heavier one than you have from ING. switch which will over come the amp draw or voltage drop through the OEM wiring which was barely big enough when NEW ... I have had to install a relay near delco type starters before to over come this problem works great after that
jtrichard is offline   Reply With Quote
Old 08-20-2016, 04:06 PM   #3
climberman
Re: Starter wiring
Thanks Jt I wondered about such a small wire from the ing. going to the solenoid.
Old 08-20-2016, 04:07 PM   #4
franken
Re: Starter wiring
Get a meter and measure the voltage to the block when the key's in the start position. Measure the battery voltage. The big negative cable should run to the block.
franken is offline   Reply With Quote
Old 08-20-2016, 04:11 PM   #5
climberman
Re: Starter wiring
The battery cable is mounted to the block. What should the voltage be
Old 08-21-2016, 07:38 PM   #6
climberman
Re: Starter wiring
I added a relay and everything seems to be ok now after a couple of days I will know for sure
Thanks for the help
Now I have another problem I will post it now
