08-20-2016, 12:23 PM | #1 |
Original Radiator
Hello, I am new to the forum and joined after buying an all original 71 C10 big block truck, ac, hugger orange/white. The ONLY rust the truck has is on the passenger side inner fender where it bolts to the core support. So my question is, I have been going thru it all and cleaning. The original Harrison radiator may not be worth cleaning per the radiator shop but the end tanks are perfect. Should I buy a new radiator or just replace the core and use the original tanks? What would be a descent price to pay for the shop using the original tanks?
Thanks |
08-20-2016, 01:25 PM | #2 |
Re: Original Radiator
I can't answer your question, but welcome to the board!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
08-20-2016, 01:49 PM | #3 |
I'd get a price on having a new one built (recored) using your tanks vs just buying a replacement. Because these trucks are still actually used by people, service items like rads are still available, not just as "restoration" parts.
They're as low as $126 on RockAuto for my '70 big block. Hard to beat that, and it must be the big one because I spec'd 402 big block in the search.
08-20-2016, 01:56 PM | #4 |
08-20-2016, 01:59 PM | #5 | |
08-20-2016, 02:57 PM | #6 |
Enter: "1971 chevrolet c10 pickup 6.6l 402cid v8 radiator"
Results: VISTA-PRO 433369 $126 SPECTRA CU369 $175
08-20-2016, 03:15 PM | #7 |
08-20-2016, 03:26 PM | #8 |
I looked into this a couple months ago for my truck. I got a spectra from summit. I should have spent more money for a different radiator. The seem between the core and tanks was the wrong contour causing an issue with the factory hold downs and rubber cushions.
The rubber cushions are reproduced as restoration parts and have a shape and contour faithful to the originals. Getting your original radiator recored will be more expensive, probably double what a cheap replacement will cost. But I think you will be much happier with the fit. |
08-20-2016, 03:43 PM | #9 |
I would go with a re-core. The replacement radiators are no longer copper/brass and don't look "right" to me.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
08-20-2016, 03:44 PM | #10 | |
08-20-2016, 03:46 PM | #11 |
08-20-2016, 03:49 PM | #12 | |
I'm about to do this on my 67 Nova SS. It is a 327 car and came with a 4 core radiator. I'm going with a high efficiency core (more fins per inch than OE), but want the tanks and brackets to be original.
08-20-2016, 04:30 PM | #13 |
I recently bought a 'Spectra' radiator from Rockauto. There was definitely some modifications needed to make it fit because of the way the tanks fit the core. It was thicker and didn't fit my 'holddown' braces. I had to take out the rubber brackets on the holddown braces and fashion homemade braces from pieces of a bicycle inner tube. The radiator sat about an inch higher which meant fashioning some hardware to move the shroud down that inch so that the fan didn't chop into it. These were mods I wasn't very happy to make but they weren't too difficult. The radiator shop quoted me $400 plus to do the recore of my original radiator which at triple the cost of the new one, seemed excessive. I don't see this ill fitting plastic & aluminum POS lasting anywhere near the 49 years that my original radiator lasted, but I have to say that it's keeping my truck cool.
Posted via Mobile Device Last edited by Freddo; 08-20-2016 at 04:31 PM. Reason: Spelling |
08-20-2016, 05:00 PM | #14 |
I bought the Vista-Pro 433369 from Rockauto a month and an half ago. It's copper and brass (all metal) and 4 core 2 5/8" thick. If you don't have the 4 core brackets, you need them and had to cut the rubber bushings down. Also the bottom of my fan shroud had a lip that had to be cut.
Here's more info on that radiator. https://www.summitracing.com/parts/pli-433369 |
08-20-2016, 05:21 PM | #15 | |
08-20-2016, 06:54 PM | #16 | |
The radiator I posted has the curved inlet just like the stock radiator. |
08-20-2016, 08:59 PM | #17 |
I bought a replacement radiator from Advanced Auto but I haven't taken it out of the box! If it's plastic though, I'll try and get something else and the one linked above is pretty nice although the link says "not available."
08-20-2016, 10:30 PM | #18 |
It's available at Rockauto (close out deal because they stopped making it). I just used the link to Summit Racing for a better description and it had a review of someone with a C10 from 2 years ago. I found another site that had that same radiator and had it listed for $400, but most websites don't have it (except Rockauto has it).
08-20-2016, 10:40 PM | #19 |
Stopped making it? I better call Rock Auto Monday then, thanks!
08-20-2016, 10:48 PM | #20 |
08-20-2016, 11:07 PM | #21 |
Welcome to the forum! What part of Houston are you in? Maybe we can get together some time and talk trucks...
Also we love pictures, soooo
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 08-21-2016 at 09:28 AM. |
08-21-2016, 02:00 AM | #22 |
I had my 4 row re-cored last summer and with the 100 degree heat today I was barely pushing 180 on the stock gauge.
There is a company out of Canada that make industrial forklift cores with thicker material and I paid about 450 bucks. It was worth it in my mind. |
08-21-2016, 02:55 AM | #23 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-21-2016, 10:11 AM | #24 |
08-21-2016, 01:30 PM | #25 |
K, thanks
