turn signal switch/lever question
new to me 65' c10. Stupid question but is the turn signal lever supposed to "click" when activating the turn signal? Mine is loose and does not click into position nor self cancel. I understand its an old truck but wasnt sure if it was supposed to do the things i mentioned. I searched the forum and couldnt find an answer, thanks in advance
Re: turn signal switch/lever question
YES clicks you need new cancel portion of switch ... IF your switch is GOOD other wise here is what you need
http://shop.advanceautoparts.com/p/d...+signal+switch Last edited by jtrichard; 08-20-2016 at 04:12 PM. |
turn signals work, ill get one of these thanks jtrichard
I forgot there are 2 plastic parts of the switch that could also be broke off you will see that when you pull the wheel they can NOT be bought separately
Huh, didn't know our trucks had auto off switches. I've just been doing it the old fashioned way.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD Thanks everyone for the help over the years. |
