Old 10-05-2003, 11:35 PM   #1
HeavyK20
HeavyK20's Avatar
Sealing Windshield Leaks
Will a new gasket fix a windshield leak, or is there additional measures that should be taken?
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 10-05-2003, 11:37 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It *should*...
or it *could*...
or it *might*...
You'll have to look for rust under the gasket, and repair any you find, but even then, many of them leak with new seals, and many more leak after a year or two of wearing the new seal.
Old 10-05-2003, 11:58 PM   #3
HeavyK20
HeavyK20's Avatar
So, should I glue the new gasket in with silicone? and then lift up the lip of the gasket after the glass is in and add more silicone?
Eric
Old 10-06-2003, 12:01 AM   #4
Longhorn Man
I don't know enough to answer that myself...some on here say that doing so will cause rust, but I am kinda unsure about that. I have used sillicone on beaters in the past and had no rust form there, but I may have gotten lucky on a brand or something.
Old 10-06-2003, 12:01 AM   #5
crazy longhorn
Fabricate till you "puke"
If you use anything to "glue " the seal, dont use silicon....use urathane. It will be a bear to remove next time tho... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-06-2003, 03:00 AM   #6
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
3M makes some great stuff.I got it at my local autobody supply store.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 10-06-2003, 03:34 AM   #7
68LSS1
68LSS1's Avatar
Mine was leaking about 2 inches in, on the bottom, on each side. When I pulled the window I found that it was rusting out there. That is where a few seams come together. POR-15 makes some stuff that would work to fix it (with the window removed). It's called POR Epoxy Putty and POR Patch.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 10-06-2003, 08:11 AM   #8
HeavyK20
HeavyK20's Avatar
Is the urethane adhesive similar to the stuff used on modern day windshields?
Eric
Old 10-06-2003, 09:25 AM   #9
truckster
truckster's Avatar
Definitely don't use silicone. You can use urethane (it's what modern windshields are installed with), but it's a very high strength adhesive, and you may not be able to replace your windshield again without buying a new gasket. The best thing to use is 3M windshield sealer, which is a liquid butyl rubber sealant. That's what was originally used on the rubber-gasketed auto glass.
If you do take the windshield out, you should definitely fix any rust. It's hard to fix a leak if the metal's rusted.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-06-2003, 10:23 AM   #10
HeavyK20
HeavyK20's Avatar
What's the deal with silicone? Does it trap moisture or something?
Eric
Old 10-06-2003, 01:57 PM   #11
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I've heard silicone against metal will make it rust. I've never seen it myself but supposedly it does.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 10-06-2003, 03:36 PM   #12
68LSS1
68LSS1's Avatar
Not only that try tp paint something that has had silicone on it. Nothing removes it. Thinner, MEK, nothing. Usually have to prime, sand, prime, sand, prime until the fish eyes stop. This is more with the silicone sprays used as lubricants though.
'68 Short Step
Old 10-06-2003, 08:17 PM   #13
truckster
truckster's Avatar
Silicone also rarely provides a permanent fix for a leak. Since it flexes after it cures, it can break loose from the glass or gasket, and then it's even harder to seal.
Old 10-06-2003, 10:26 PM   #14
HeavyK20
HeavyK20's Avatar
Thanks for the info. Just one more Q.
When it comes to buying a new gasket are any better quality than others, or is everyone carrying about the same stuff?
Eric
Old 10-08-2003, 10:48 PM   #15
Longhorn Man
TTT, some one able to answer the gasket Q? I may be looking for a replacement soon.
Old 10-09-2003, 05:22 AM   #16
BobbyK
BobbyK's Avatar
I got mine from GMC Pauls.Great fit and good quality rubber.
Old 10-09-2003, 08:50 AM   #17
Huck
Huck's Avatar
I asked the same question re. windshield gasket quality a while back without a good answer. Here's the problem. Most of the stuff the dealers get today is overseas junk. Sometimes it's OK and sometimes it fails in a year or two. I've bought windshield rubber that was too big and the dealer told me it was made that way on purpose to allow for shrinkage!!!! In another case it was too small and in fact did shrink leaving openings where there were none the year before.
These trucks must have leaked when new as the dash has holes drilled to allow for drainage in the corners!!! Soff seal makes a gasket with a lifetime guarantee-$65.or so--of course if it leaks and you paid someone to install it, you can get a new one -assuming you can get the old one out without ripping it in the process--maybe?? They can be a bear to install especially if you have the delux model with the stainless trim. So "what to do" you say----choices:
Get one from any dealer and take your chances--about $40.+ship
Get one from Soff Seal for about $65.+ship and take your chances
Have a glass place get one that they guarantee--pay them and hopefully get a guarantee for leakage and parts replacement--lifetime. Most glass places will not guarantee their labor and your old windshield if they replace the gasket as they broke a windshield on my truck in the process and ruined the gasket as well.
Get Glass Coverage from you insurance company and then~~~~
Scratch you head like I am doing trying to figure out what to do
In any case, if you remove a windshield make sure you do a real quality job of rust removal and frame prep before the installation of a new one. POR15 paint, + their gooey patch stuff works well.
Then, after the job is done, you may as well get some of that 3M Urethene stuff just in case!!!!!!!!!
Huck is offline   Reply With Quote
Old 10-09-2003, 12:20 PM   #18
72longbed
72longbed's Avatar
Just did a new windshield and gasket 3 weeks ago. I used a Steele Co. gasket, (deluxe model), and even the installers commented on the quality of it. Very heavy duty quality rubber compared to any others that I have handled.
Just my .02
72
72longbed is offline   Reply With Quote
Old 10-09-2003, 03:35 PM   #19
HeavyK20
HeavyK20's Avatar
Where did you buy the Steele Co. gasket?
Eric
Old 10-09-2003, 03:41 PM   #20
72longbed
72longbed's Avatar
I got it at the Carlisle, Pa truck show a few months ago. The have a web site, just search for: Steele Rubber Products.
72
