08-21-2016, 11:52 AM | #1 |
Ram Horn Bolts
Does anybody know the part number for ARP bolts for exhaust manifolds? I want to replace the standard bolts I have now.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
08-21-2016, 01:55 PM | #2 |
Re: Ram Horn Bolts
I dont know the arp # since i used grade 8 bolts.
Ya gotta watch though cause they are not all the same length. the inner bolts are slightly longer than the outers. Im sure arp knows this but i would make sure. Since most arps are 12 point they usually have a small head with a small diameter washer. I used smaller diameter thick washers sorta like the oe ones with my grade 8's. I "think" the nut& bolt store called them sae washers. Also ya might check too see if your gonna need any studs for bracket mounting purposes.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
