Old 08-21-2016, 12:47 PM   #1
54blackhornet
54blackhornet's Avatar
G70 G50 Rear Leaf Spring Lowering
I would like to lower my 71 GMC 1500. Leafs with G50 Heavy Duty Springs. Question , can you remove the overload G50 and get any drop at all ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 08-21-2016, 03:43 PM   #2
KY_GMC
KY_GMC's Avatar
Re: G70 G50 Rear Leaf Spring Lowering
I had this same option on my GMC.
The only way to get a drop is to do a flip kit. But, this nets around 6.5" drop with the G50 overload springs removed. And the axle will be about 3" from the frame rails.
I did the DJM flip kit and cut 2" off the stock bump stops. I did not do a c-notch. It sits very nice and requires stiff shocks in the back. I also relocated the rear shocks so that they sit more upright. There are extra holes in the upper shock mounting bracket where you can mount the threaded shock stud.
This shows the picture before I relocated the shock which improved the suspension geometry.
I combined this with a 4" drop in the front. I think that the stance works pretty well.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 08-21-2016, 08:27 PM   #3
Mike C
Mike C's Avatar
I did pretty much same thing. The overloads don't have much affect on anything but load carrying as far as height. I removed mine because they hit the CalTracs. I did an ECE disc conversion and used drop spindles and 2" springs in front.
I also relocated rear shocks and used (4) stock length fronts all around.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-22-2016, 12:08 PM   #4
54blackhornet
Thanks guys for the info, both your truck look great ! Appreciate it !
71 C-20
07 Magnum RT AWD
