08-21-2016, 02:11 PM | #1 |
Moderator
My bed is a pond
65 LWB fleet. My bed is holding water after a rain. A lot of water. It will drain really slowly over a couple of days (drip at a time) as well as evaporate. The bed is a bit canted so it pools in the front passenger corner. I guess I need a drain hole. Should I put it through the corner of the wood, the front panel, or the bed side?
08-21-2016, 03:54 PM | #2 |
Moderator
Re: My bed is a pond
Had a quick search for "water in bed" and found someone with a similar issue on a 67-72. Looks like there is supposed to be drain holes in those trucks, so I'll replicate them on mine.
http://67-72chevytrucks.com/vboard/s...d.php?t=494735 |
08-21-2016, 04:02 PM | #3 |
Check The Champ, Demonstrator
I'd go through the wood. Steel will rust after drilling. Best to go in the 3/4" range so you can poke your finger through now and then when it begins to clog up with leaves and such. Both sides of the box so it can drain either side.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
08-21-2016, 06:39 PM | #4 |
Moderator
Yes, it will be a lot quicker to drill through the wood, too!
08-22-2016, 12:23 AM | #5 |
Post Whore
Never had that problem! Partly cause the wood in my GMC's bed is 50 years old!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-22-2016, 06:49 AM | #6 |
Moderator
Yeah, my bed wood is actually plastic TREX. Great for outdoors, also great at being waterproof... guess I should have cut a couple boards short! lol
08-22-2016, 11:20 AM | #7 |
Jay do you park on a downslope? When you cut your trex did you follow Paul's measurements? They call for a drain channel every so often.
I'm considering options for doing my bed and was thinking about trex so I'm interested in this pooling problem.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD Thanks everyone for the help over the years. Last edited by Praxiss454; 08-23-2016 at 02:15 AM. |
08-22-2016, 04:25 PM | #8 |
I have never had that problem but that is probably because it no longer rains in Los Angeles.
08-22-2016, 09:02 PM | #9 |
Moderator
