Old 08-21-2016, 05:38 PM   #1
Ghost's68
Ghost's68's Avatar
ECE Rear kit with ford 9"
I'm just waiting on my ECE rear springs to arrive So I can install my 4/6 drop kit. I have a question though regarding the Track Bar included in the kit. Do I remove the bar installed on my Ford 9" rear end? Sorry for the dumb question but I just wanna make sure before I do the install. Here's some pics for you guys. Thanks
Ghost's68 is offline   Reply With Quote
Old 08-22-2016, 07:22 AM   #2
andrewmp6
Re: ECE Rear kit with ford 9"
If it comes with a panhard bar then yes you have to replace yours,And being your using a non oem axle you might have to make a mount for it.
andrewmp6 is offline   Reply With Quote
Old 08-22-2016, 02:21 PM   #3
PGSigns
PGSigns's Avatar
If you ordered the super track bar it goes to the trailing arm and not the rear end.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-23-2016, 08:07 PM   #4
Ghost's68
Ghost's68's Avatar
Jimmy
Thanks guys. I will remove the pan hard bar and replace it with the ECE super track bar.
Old 08-24-2016, 10:49 AM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
My understanding is the standard long track bars do not clear the housing on a 9". I know CPP makes a "Bent" version that is designed to clear the housing. I used one to clear my larger aftermarket diff cover.
http://www.classicperform.com/Store/...ck/CP32021.htm
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-24-2016, 11:39 AM   #6
Ghost's68
Ghost's68's Avatar
That's interesting. I called the guys over at ECE and asked that specific question before ordering the kit. I was told it would fit. I haven't got to installing it yet.
Old 08-24-2016, 09:39 PM   #7
chevy_mike
chevy_mike's Avatar
I would trust them if they told you that.
