Water leaking from head
I have about 49 miles on this 283 it sat for about 3 to 4 years before I ran it. Yesterday water was dripping from it after I pulled in the garage after shut it off. But from the back of the motor. Today I took a closer look and it is coming from the back of the heads. I could be wrong because it is so slow but I can't see anywhere else it could be from. And on both sides one side more then the other. I am hoping I just need to check the torque and tighten the head bolts.
![]() ![]() Join Date: Oct 2014
Re: Water leaking from head
That's what I would start with, checking the head bolts and also the intake bolts too. I'd check the oil to make sure there doesn't appear to be any coolant in the pan.
I did check the oil and there isn't any coolant it looks good and the exhaust is clear.
Engine history? miles,rebuilt, head work, never been apart?ECT.?
Post Whore
![]() Join Date: Mar 2013
Check the casting plugs to....just had one go at the rear head of my gmc v6.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
TJ none in head on 283....... AND a big A++ that you know what the "plugs" are for
Post Whore
Oh ok, Not up on the 8's as much as I am on the 6's. haha I have heard them called, casting plugs, core plugs, freeze plugs, soft plugs, block plugs, sand plugs, and just plain ol plugs!
the one thing they are not is "freeze plugs"
The history is that I bought it from a guy that had it rebuilt. It sat around for a while before I bought it. And I didn't start it for at least two years. It runs great has a lot of power and ideals smooth. Clean exhaust maybe running a little rich. I was putting a electric fan on and it got a little hot because the sending unit wasn't working properly and they had to send me another one. But we drove it after that and there wasn't a leak. The leak just happened yesterday.
I'll bet it's the intake gasket leaking coolant at the rear. Common SBC problem.
Wow thanks Andy now that you say that it could be where it is coming form.
#13 |
When you install the new gaskets use a coat of aviation permatex around the water jacket on the head & on the intake side also. And don't forget that all but the end bolts go thru into the underside of the intake & use some permatex on the threads to keep oil leaks down on the intake beside the carb. Also one bolt on each side will intersect with a push rod if it's too long so watch for that.
#14 |
I was thinking maybe I should try to tighten them first.
#15 |
IMO i would pull off the intake strip off all old gasket material off intake and heads .... also clean all bolts with a wire brush so all threads are clear of gummed oil residue . and re gasket it with new intake gaskets ... and for gaskets i always use Gasket cinch ... imo best stuff around also yes use permatex on the newly cleaned bolts
#16 |
I am really filling stupid now, when I seen the leek I never once opened the hood. Today I opened the hood and there was water on the intake it came from the sending unit for the electric fan. Put one layer of plumbers tape on it and problem solved.
Thanks for all of your time always appreciate everyone. |
#17 |
I think you should pull that intake & reseal it anyway, just to make us happy!
#18 |
I took it for a long drive and it isn't leaking anymore
#19 |
That's great! Now I wish the head gaskets on my S10 would stop leaking that easy...
#20 |
Well I spoke to soon the leak from the sending unit was solved but I still had another. It was coming from the back passages side freeze plug. I took the easy fix and pored in some blue devil. Now there are no leaks!!! What would cause a freeze plug to leak.
#21 |
Either NOT replaced or installed WRONG when "rebuilt"
READ THIS please note "incorrectly called" https://en.wikipedia.org/wiki/Core_plug Last edited by jtrichard; 08-25-2016 at 01:28 PM. |
#22 |
HAHAHA! Wondered who would call this out!
What's Blue Devil? Stop leak? Your radiator will thank you for that-Not! ![]() |
#23 | |
![]() Last edited by WOLFMANmike; 08-25-2016 at 04:31 PM. |
#24 |
All that crystals looking stuff was much worse it's been sitting now for 2 years but my Radiator was so full of that stuff I tossed it out .
#25 |
Here is the pic
