Old 08-21-2016, 09:02 PM   #1
trkfrmr
71 c20 brake questions
Hello, I put a 1971 C20 power disc/drum brake frame under my '67,someone had removed the brake lines so I ordered a new set,not thinking about tees and union connectors.Does anyone have 71 or 72 c20 minus engine that they could send me a pic of the brake line setup under the master cylinder so I can order fittings?I am using the '71 booster/cylinder setup.Also,is the porp valve same as half ton?Thanks.
trkfrmr is offline   Reply With Quote
