Old 10-06-2003, 12:27 AM   #1
gutterman01
a arm bushings
which would you say is better poly bushings or orginal rubber and where is the lowest price on all bushings?
gutterman01 is offline   Reply With Quote
Old 10-06-2003, 07:47 PM   #2
crazy longhorn
Fabricate till you "puke"
I cant help on where the best price is, but the poly bushings are no doubt better than the original rubber pcs. You might start at Summit racing, look in Energy Suspension. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
