Lower control arms
I'm looking for a set of lower controls arms 1974 1/2 ton
Re: Lower control arms
Moog used to make new replacements. Rock auto has the right one in stock: MOOG RK621646. You might get lucky if you search around and find someone that still has a left one in stock. Otherwise it's off to the scrap yard to pull a set and rebuild them. I have occasionally seen some for sale on ebay.
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
thanks Mike im looking here in san diego at junk yards now
I have a stock one for rebuilding off my 82 you are welcome to have it. If it works for your application and you want to pay shipping.
Very generous of you I appreciate that. I think we have a pair now. If you ever need anything drop me a message maybe I can help you.
No problem good luck to you with build
I just had a lower ball joint break and went though an ordeal getting it fixed. First, I bought new ball joints (wanted to change them all) but the lowers were too small to fit the hole in the lower arm. Tried buying new lower arms. No body had them. Bought a set from NAPA but they were misidentified. They fit a C20 truck which seems to be a industry wide problem. Several Internet sources say they have ordered lowers and got C20 parts. I think LMC has correct repo parts - we were about to go that route.
Finally fixed mine with some over-sized ball joints my front end shop ordered from NAPA CHASSIS. They came from somewhere in California. Part number off the box is 260-11180S and the bar code number is 7 57522 43149 1 I'm not sure if the leading 7 or ending 1 is part of the number. Good luck |
