08-22-2016, 06:54 AM | #1 |
Addding accessory power ignition switch to 1968
I just finished up LS swapping my 1968 Suburban. This suburban does not have an acc postion on the ignition switch. Is it possible to just change the switch to a 1972 switch with acc position ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-22-2016, 09:44 AM | #2 |
Re: Addding accessory power ignition switch to 1968
I tried that I'm my 67 and the switch still worked in start and run but had no accessory. I thought 68 had accessory? Maby you have a 67 switch in a 68. If your 68 is wired for accessory like it should be you may be able to change it and have it work.
08-22-2016, 09:47 AM | #3 |
my k10 truck has a 75 steering colum, has steering lock, acc, tilt, etc so i say its an upgrade.
08-22-2016, 10:00 AM | #4 | |
The Older Generation
The wire loom is different. You could install the later switch and add the wires you need to the connector if you had to. LockDoc
08-22-2016, 12:02 PM | #5 |
It might be easier to replace the points with a Pertronix and then not worry. I think the only reason we had ACC separate from IGN was largely not to burn your points while sitting with the key on but engine off.
08-22-2016, 05:57 PM | #6 | |
I dont like the PCM having power when its not running
