Old 08-22-2016, 02:05 PM   #1
nitrosport_5
nitrosport_5's Avatar
Help with 1972 k20 bumper bracket delema
Ive got a 1972 Chevy k20 longbed fleetside and im curious what bumper brackets are correct for what i need. i purchased these brackets (pictured) from a member here and was told they are correct for my truck. i never had a stock bumper on it so i had no idea what brackets i needed.
once i got them the holes on the frame didnt line up. the furthest rear hole would catch the bracket but thats it. after lookng at the truckandcarshop catalogue, it showed that the style of brackets i purchased were for a 2wd truck and that there was a set with further spaced bolt holes meant for a 4wd so i went ahead and purchased an aftermarket set of those brsckets. my frame holes line up just perfectly but the bumper fits like crap! its just a straight bracket with holes so i cant see how the aftermarket could screw them up THAT bad. it looks like if i used the first brackets i have it would alow the bumper to follow the contour of the body better but indont have a second hole for them.
here is a link to the page with the brackets http://www.truckandcarshop.com/trucks60_72/t60_013.html
so what style of bracket is correct? if the set i attached a picture of is correct why would my frame be drilled for the other style? its the original frame with number matching my cab that is all originally a 3/4t chevrolet 4x4. thanks
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT
"Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C.
"1968" C10 Shortbed project
nitrosport_5 is offline   Reply With Quote
Old 08-22-2016, 02:13 PM   #2
gable74
gable74's Avatar
Re: Help with 1972 k20 bumper bracket delema
Here is my 72 K20 with what I can only imagine are NOT the original bumper brackets.
1972 K-20 Custom Camper
1971 K2500 Custom Camper (Sold)
2014 GMC 2500HD DMAX
gable74 is offline   Reply With Quote
Old 08-22-2016, 02:14 PM   #3
gable74
gable74's Avatar
I bought a new diamond plate bumper that came with the following bumper brackets for install. I am anticipating having to do a little welding but hoping I don't.
Old 08-22-2016, 02:21 PM   #4
nitrosport_5
thanks for the reply, yours looks like it is a step style bumper. im trying to get one of the sport style chrome bumpers installed. i had a step bumper originally but it didnt fit with the way my restoration was heading. my exhaust guy told me to pie cut the brackets to make the bumper fit correctly, but i dont know why it should need to be done with a stock frame, stock bed, stock style bumper ect. i just seem to have the wrong brackets
Old 08-22-2016, 02:27 PM   #5
gable74
gable74's Avatar
Here is my bumper.
Old 08-23-2016, 05:11 PM   #6
nitrosport_5
Originally Posted by gable74 View Post
Here is my bumper.
thats quite different than the one im trying to install. ive got a factory chrome bumper. i found a pic on google of the style im trying to put on.
anybody else have any ideas to what brackets i need to be using?
Old 08-23-2016, 07:54 PM   #7
Tdrcreyn4
Tdrcreyn4's Avatar
I have a 1969 K20 that I put the sport bumper on like you are trying to do. I ordered the inner and outer brackets from LMC along with the splash guards. It was listed in the catalog as 4x4 short bed brackets and I have a long bed but they worked just fine and used the factory holes. Each side has two pieces and they bolt together.
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 08-23-2016, 10:01 PM   #8
jerry moss
Born Psycho
jerry moss's Avatar
real 4x4 rear inner brackets are longer than the ones pictured and have a thick piece of metal welded inside for support. do a search on here, a member was recently selling a set of "real" 4x4 inners. the outers are the same.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 08-23-2016, 10:15 PM   #9
nitrosport_5
well, thats what ive got, although aftermarket. so i have the correct mounts on it, they just fit like crap. the bumper should follow the contour of the body more from the side correct?
Old 08-23-2016, 10:28 PM   #10
davischevy
davischevy's Avatar
Did you try switching the brackets side to side, IE, flip them over?
Larry
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 08-23-2016, 11:11 PM   #11
nitrosport_5
Larry
hmmm, i dont know if i tried that or not. ill have to see if its possible.
Old 08-23-2016, 11:59 PM   #12
midniteblues
midniteblues's Avatar
I do believe they can only fit the side they are designed too fit on.
the bump out part is a relief for the rear sill bed bolt since it drops down so close too the inner frame rail.
I know this pic wont be much help since these are on my 2wd 67 but it might tell ya if they sent you 2wd coil spring brackets. These are right about 15 1/4" long and practically 5" on center between the frame bolts.
You can see just after the first bolt there is a extra hole on these rite about 13 1/2".
Hope i helped ya some how here.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 08-24-2016, 01:29 PM   #13
davischevy
davischevy's Avatar
Here's a picture of mine. Looks the same as yours. Your right side outer brace appears to be correct.
other Larry
Old 08-24-2016, 01:33 PM   #14
davischevy
davischevy's Avatar
After studying your 3rd pic, your inner braces are turned correctly. They can't go the other way, they will hit a bed mounting bolt.
Larry
other Larry
Old 08-24-2016, 01:36 PM   #15
davischevy
davischevy's Avatar
I just looked at two more trucks here and they are just like yours. You could use tapered shims to get more "angle" on it.
other Larry
Old 08-24-2016, 01:42 PM   #16
nitrosport_5
thanks Larry for taking the time to look into this!
i guess i wont let it bother me as much knowing it isnt too far off. i had to add about 1/4" of shims on the driver side to keep the bumper in line. i will try and play with it a little bit more if i have some time, otherwise i may just leave it for a while. im getting too picky, i sit and look at the truck and pick apart stupid little issues thst bug me, but nobody will ever notice!
